Having trouble.....car hesitates/breakdowns at WOT....
Old Jan 5, 2002 | 06:39 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Default Having trouble.....car hesitates/breakdowns at WOT....
any ideas where to start....what to check out...
I figure.... Cap, Rotor, somehow check the injectors (anybody know how to do this)...I remember some one posting something.....
any other ideas?
thanks Jeff
Old Jan 5, 2002 | 07:32 PM
vader86's Avatar
vader86
Default Re: Having trouble.....car hesitates/breakdowns at WOT.... (XtremeVette)
those would be my first thoughts as well, you have to check the resistance on the injectors to tell if theyre bad or hook up a fuel pressure gauge.
Old Jan 5, 2002 | 07:44 PM
XtremeVette
Default Re: Having trouble.....car hesitates/breakdowns at WOT.... (vader86)
anybody know what the resistance should be at idle on the injectors?.....can i use a regular meter on them?
thanks
Old Jan 5, 2002 | 08:29 PM
dizwiz24's Avatar
dizwiz24
I had this problem on my 93. Occasional hesitation under WOT above 4000 RPM. Especially did this when hot. Turned out to be a bad opti. New plugs and wires before replacing the opti helped me out a lot (to the point where it hardly ever did it anymore)
Old Jan 6, 2002 | 02:33 AM
XtremeVette
Default Re: Having trouble.....car hesitates/breakdowns at WOT.... (dizwiz24)
update!!!.....she's stumbling bad now.....does it at part open throttle now....and even when Iam not really getting on it.....at stop signs and coming to a stop in a parking lot....died twice.....when i restarted it.....did not like it....started up...rpms jumpin back and forth until finally smoothed out.....feels just like fuel shut off is occuring.....like when you run your car down to 1/8 of a tank; floor it going around a corner......you get the cutting out feeling.....NEED HELP GUYS....really want to fix this.....thanks jeff
[Modified by XtremeVette, 12:35 AM 1/6/2002]
Old Jan 6, 2002 | 02:55 AM
vader86's Avatar
vader86
well if shes doin it all the time, then id say cap, plugs, wires, and rotor should be changed, if youre anxious to find an answer id run a search
Old Jan 6, 2002 | 03:35 AM
ol,RJ's Avatar
ol,RJ
I'd check the fuel pressure too, it could be the pump going out.
Old Jan 6, 2002 | 05:38 PM
XtremeVette
Default Re: Having trouble.....car hesitates/breakdowns at WOT.... (ol,RJ)
UPDATE...FIXED....
Bad Cap and Rotor....had black poopie all on it....
this is like my 4th since I have owned the car....hmmm i dunno bout that....but this last one lasted bout yr and a half....or 10,000 miles....
well she's back running excellent again....I swear feels like night and day...i picked up like 20-30 extra horses...
well ttyl
jeff
To Having trouble.....car hesitates/breakdowns at WOT....
