need help with code 43
Old Sep 11, 2008 | 12:22 PM
ICANTDR55's Avatar
ICANTDR55
Default need help with code 43
Car; 1993 Corvette coupe auto. Put in lt4 hot cam kit. Car ran fine for about a week. Getting ready to go to track, gave it 1 more test run and the vette starts to run bad. I made it home, and now it only starts and goes dead. when it does run, it runs bad and goes dead when it goes to close loop. only consant code is 43. I ran test according to flow chart. It said I have bad knock sensors or ECM. The knock sensors are new. With the scan tool hooked to the system I can hit on the manifold and the scan tool picks up a knock singal. I have tried another Dist., module, coil, and computer. same results. I replaced the mem-cal and now when the car starts it runs fine for a few minutes and then it starts to shut down like its not getting any fire and the scan tool shows a code 41 est open circuit. When the car warms up it runs fine and shows no codes. I have replaced everything that I know to replace and still get the same result. Do you guys have any I dea what the problem might be?
Old Sep 17, 2008 | 01:55 AM
ICANTDR55's Avatar
ICANTDR55
some feedback would be nice.
Old Sep 17, 2008 | 09:13 AM
Jim Martley2's Avatar
Jim Martley2
To be honest with you, it sounds like the computer is the problem. I went thru a similar situation on my wife's 93. With NO warning it started to throw all kinds of codes and would die out if you tapped on the computer with your finger. Here is a link to my post on the subject.
http://forums.corvetteforum.com/show...178&highlight=
Good luck!!
Old Sep 17, 2008 | 11:35 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
It could be the ICM.Did you use the heat sink paste when you replaced it? Since you said it runs OK for a few minutes it may be either bad and/or heating up. I don't get the relationship between the memcal and the 43 though. I would use the trouble shooting tree in the FSM for the ICM first.It could be as simple as a bad connection.
Old Sep 17, 2008 | 12:27 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
You can remove your ICM and have it tested at most auto parts stores like AutoZone or NAPA.
Have you tested your spark module? It's located on the HVAC blower motor on the passenger side of the car. That can also throw a Code 43.
Since your knock sensors are new, if that doesn't fix it, I, too, am leaning toward your ECM. They're hard to find for 1992 and 1993 models, though.
You'll probably wind up getting a re-man or O.E.M. salvage yard unit. And don't forget to save your PROM chip as you'll need it for the replacement ECM.
Old Sep 17, 2008 | 11:37 PM
ICANTDR55's Avatar
ICANTDR55
The code 43 is the esc(knock sensors) open circuit or shorted. I can tap on the manifold and the scan tool will show a that the knock sensors are picking up a knock and that is not possible if I have an open circuit. The ecs module is programmed into the mem- cal.
Old Sep 18, 2008 | 10:09 AM
Redeasysport
I thought you said the 43 was gone and now you have a 41? Everything is programmed through the memcal but I have rarely heard of one being bad. Usually the ECM. The KS has a module that gives the ecm data.So what is the problem 41 or 43 or both?Either way I would be looking at wiring first.Check the resistance on the 2 ends of the wire. I mistakenly read code 43 from the LT5 table and thought ESC.
After doing some checking I found 43 to be KS and 41 to be ICM.
Old Sep 18, 2008 | 10:56 AM
mikey whipreck's Avatar
mikey whipreck
This applies to my 1985... I'm not sure if the same logic fits on yours.
On my coupe, I was getting a constant code 43, but when I ran through the flow chart everything always checked out fine. In the mean time, I fixed an array of problems - one of which was an excessively noise cat converter (pieces were bouncing around inside), at which point my code 43 stopped appearing. I think in my case, the knock sensor was seeing constant detonation (which was actually the cat), and trying to retard the timing. After so many seconds of not being able to stop the knocking, the ECM thinks something must not be working, since the knock sensor is still transmitting data, and throws a code 43. Which was not related to the real problem on my coupe at all.
Is that relevant in your case? I do not know.
To need help with code 43
