86 Turn Signal flasher...
Old Jan 6, 2002 | 01:22 AM
jimbos86vette's Avatar
jimbos86vette
Default 86 Turn Signal flasher...
Anybody here know where the Turn Signal flasher is?????
Old Jan 6, 2002 | 01:47 AM
JonM's Avatar
JonM
Default Re: 86 Turn Signal flasher... (jimbos86vette)
You have to remove the hush pad on the passanger side. Lay on your back, look up under the dash. You will see it just to the right of the Multiuse panel and to the left of the ECM. Get a long screwdriver or something like that. Pass it up behind the flasher and pop it out. (Its on a "C" clip that goes about two thrids around the flasher. You will have just enough wire to pull it down to change it.
Old Jan 6, 2002 | 10:53 AM
jimbos86vette
Default Re: 86 Turn Signal flasher... (JonM)
Thanks I'll give that a shot!!!
Old Jan 6, 2002 | 04:36 PM
jimbos86vette
Thanks JonM, it was right were you said it would be, my turn signals flash again!!!!
:cool:
To 86 Turn Signal flasher...
