air pump eliminator? what else gets removed?
while changing the water pump on my 86 .i went to do a tpis air pump eliminator.what else can be left off ? air switching valve and air diverter?.can i cap the pipe that goes to the exhaust manifolds? and also theres a vacumm line that splits into 2 and goes to the fuel pressure regualtor and the plenum.
Received 1,401 Likes
I yanked all the pipes off, and taped up all connectors.
The tubes can be left alone though, you dont have to cap them.
You can loose both valves and all the plumbing. Before headers, I cut the air tree off the manifold and mig welded the holes.
I cut the vacuum line and ran a single from plenum to fuel reg.
