lowering 84 vette.
Old Sep 15, 2008 | 05:25 PM
defo98's Avatar
defo98
Default lowering 84 vette.
Can you lower an 84 vette withouth buying aftermarket parts?
Old Sep 15, 2008 | 05:30 PM
StealthLT4's Avatar
StealthLT4
You can lower the rear a little bit, but not the front.
You can look at one of the lowering DIY's floating around here for pictures and specifics, because the rear kit is simply longer bolts than stock. You can take the nut on the bottom of the bolt (supporting the underside of the spring) on each side and back it off to the very bottom of the bolt. That's as low as you can go on stock gear.
Old Sep 16, 2008 | 07:30 AM
Mr X's Avatar
Mr X
You need install lowering wedges on front and some welding.
To lowering 84 vette.
