Operating Temperatures?
Old Sep 15, 2008 | 08:13 PM
myturn89's Avatar
myturn89
Default Operating Temperatures?
As i am a novice owner i have a couple questions - this is for an 89:
1) what is the normal operating temperature to which the coolant fan comes on? I had the car idling this evening and it switched on at about 220
2) how does that temperature relate back to the type of thermostat that i may have. Is there a way to determine if i have a 160 degree thermostat based on the operating temperature
3) Normal oil pressure number during operation - it seems to ramp up during the start up (50ish) and then when the operating temperature goes up the oil temperature goes down (at idle) around 30ish.
Do these numbers sound about right?
Thanks for any advice in advance.
Old Sep 15, 2008 | 08:25 PM
vader86's Avatar
vader86
http://temp.corvetteforum.net/c4/vad...erheating.html
Your oil pressure is normal.
Old Sep 15, 2008 | 10:33 PM
Lichen's Avatar
Lichen
Originally Posted by vader86
What Vader86 said. You can lower your coolant temps by re-programming the fans to come on sooner, but the oil temps and pressure are normal.
To Operating Temperatures?
