How often for tuneup on 95 LT1?
Old Jan 6, 2002 | 04:39 PM
WhiteHorse's Avatar
WhiteHorse
From: Wichita, KS, USA Vote John McCain in 2008 God=Santa Claus 4 adults
Default How often for tuneup on 95 LT1?
I have been told that I don't need to do a tuneup until 100,000 miles but I'm sure that's highly optimistic. How often do you guys go in and replace plugs and wires? Also, how often do you replace the fuel filter? Other than the air filter, is there anything else I need to replace regularly? Having never seen an optispark, is there a distributor cap, rotor, etc.? Thanks in advance. Sorry to sound stupid but I'm new to this particular engine (been playing with rotaries too long :lol: ). Thanks in advance.
Old Jan 6, 2002 | 04:43 PM
bogus's Avatar
bogus
Default Re: How often for tuneup on 95 LT1? (WhiteHorse)
nope... the ACDelco platnuims are not going to last that long... I suspect 60k is about max...
Old Jan 6, 2002 | 04:52 PM
Scott LeMuke's Avatar
Scott LeMuke
I replaced my Delco Platinums at 90,000 miles. The gaps had burned open to .066". I would definitely at least take them out and regap them before 90,000 miles. Since it is so time consuming to take out the old plugs, it is probably wothwhile to put a new set in rather than to reinstall re-gapped plugs. :)
Old Jan 6, 2002 | 04:56 PM
plastic thunder's Avatar
plastic thunder
I started picking up engine noise in radio at about 37500. had two bad plug wires. Replaced both plugs and wires.Fuel filter will be replaced at next oil change about 1000 miles from now.only had car for about 3000 miles and replacing all I can.Didn't have a service record :yesnod:
Old Jan 6, 2002 | 05:25 PM
vader86's Avatar
vader86
no the opti is not really like a distributor cap and rotor. Id just change plugs and wires every 50k at least, fuel filter at the same time, maybe less.
Old Jan 6, 2002 | 11:20 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
First set of plugs was at 55,000 only because I had them out to install headers and the second set of plugs and first set of wires at 94,000 when i pulled the motor for the head and cam. Never had a problem.
[Modified by mackeyred96, 5:45 PM 1/7/2002]
Old Jan 7, 2002 | 03:13 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
For a standard daily driven C4...
Trans fluid (Auto or Stick)- every 30K miles
Oil - every 3k miles
Differential Fluid - every 50K miles
Coolant - every 2 years
Power Steering - every 30K miles
Brake Fluid - every year
Spark Plugs - every 25K miles for copper core or 50K miles for Platinum
Spark Plug Wires - every 50K miles
If you race it, these get thrown out the window and an accelerated version comes into play.
Old Jan 7, 2002 | 06:30 PM
BrentDev's Avatar
BrentDev
Default Re: How often for tuneup on 95 LT1? (Vette92)
In my GM service manual, andjust about everywhere else I have seen with the LT1 - it says (paraphrased) if the fuel system ain't boggin down - dont mess with it. I.e. - do not replace the fuel filter until it starts to dog down.
Whether or not that means anything - who knows. But, I havent changed my fuel filter yet.
Old Jan 7, 2002 | 06:55 PM
Chris@SD's Avatar
Chris@SD
:yesnod: :yesnod: :yesnod: :yesnod: :yesnod:
The only thing that might be a little optomistic is the Copper plug life. Then again, we don't deal with too many regular daily drivers that are not raced also!!!! :cool:
Old Jan 7, 2002 | 07:59 PM
WhiteHorse's Avatar
WhiteHorse
Thanks for all the responses guys. It's much appreciated. :cheers:
Old Jan 8, 2002 | 11:52 AM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: How often for tuneup on 95 LT1? (Chris@SpeedDemon)
I've actually never tested the 25k miles for copper cores because I change mine about 4 times a year and only put about 3-4k miles per year (assuming it runs). :crazy:
To How often for tuneup on 95 LT1?
