Test Pipe for Under $20.00!
Old Sep 16, 2008 | 10:58 AM
shamdave's Avatar
shamdave
Default Test Pipe for Under $20.00!
I recently did a test pipe on my 85 and after looking high and low, $60.00 for a test pipe? no freaking way here is what i did
1) take off the converter and it is a bear. get some pb blaster you will need it
2) cut off the converter flanges leaving at least 2"s of pipe. I used a sawz all worked very fast
3) Go purchase a section of pipe I used (i think i ued 2 3/4") If you have a flange tool flare both ends if not no big deal. you will need to "coax" it into the oval inside the flange pipe.
4) using a BFH (bid f'ing hammer) hammer the new pipe pipe in the flanges pipes, after getyting them in there measure the total length from outer flange to outer flange should be 16" mark and cut accordingly.
5) re assemble and drill and place 2 screws to hold ino place on the top and bottom of each flange. (or weld if you have a welder)
6) use a good muffler seam sealer or JB Weld and fill in any visible gaps around the flange pipe and the new pipe.
wait to dry and re assemble
Go collect 40 bucks for your old converter.
Pipe=8.99
Sealer=3.99
Screws=.10
Sawz all Blade=2.99
Total = $16.07
Cheapest HP gain i can think of and it sounds way cooler
Old Sep 16, 2008 | 11:58 AM
Master__Shake_'s Avatar
Master__Shake_
I wouldn't go around telling people to cut out their cat unless for two things:
1) Their state doesn't require strict emissions testing
2) You can trick the inspector to think the pre-cats are the main one.
It IS illegal to drive with a delete pipe, afterall, so I wouldn't boast too much.
Old Sep 16, 2008 | 12:06 PM
shamdave's Avatar
shamdave
**for track use only not recomended for street use blah blah blah
My thread is if you wanted to build a cheap Tp and not get milked for 60 bucks here is how you do it.
Old Sep 16, 2008 | 01:10 PM
daytonaer's Avatar
daytonaer
Pipe=8.99
Sealer=3.99
Screws=.10
Sawz all Blade=2.99
Total = $16.07
TEST PIPE being the key word.
Instead of using jb weld or muffler seam sealer I would suggest red high temp rtv. I started using it on exhausts after I saw them using it on a tv show, Works great! Way cheaper and easier than jb weld, and muffler weld is like clay. It doesn't burn, just be sure you let it dry before starting up to prevent it from blowing out.
Old Sep 16, 2008 | 01:16 PM
rickneworleansla's Avatar
rickneworleansla
For those that don't like to weld you may be able to find these somewhere cheap.
Old Sep 16, 2008 | 01:59 PM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
Nice work finding a solution
I had a local exhaust shop make me one for about $40 I think. I had them make it exactly match the rest of the system so I would not have to modify any of the other hardware - makes it easy to swap it with a cat.
Old Sep 16, 2008 | 02:05 PM
my83432's Avatar
my83432
Where did you find a test pipe for a 85? I would be happy to pay $60 not to do all that work.
Old Sep 16, 2008 | 02:53 PM
shamdave's Avatar
shamdave
http://cgi.ebay.com/ebaymotors/CORVE...spagenameZWDVW
Old Sep 16, 2008 | 04:49 PM
Road Agent's Avatar
Road Agent
You drive a Corvette and worry about $60.
Old Sep 16, 2008 | 06:52 PM
BlackC6LS3's Avatar
BlackC6LS3
What's wrong with not wanting to get ripped off? A Vette is just a car...
Old Sep 16, 2008 | 07:07 PM
MK 82's Avatar
MK 82
Why do they call it a test pipe and why will no reputable muffler shop touch it?
IT'S ILLEGAL AND CARRIES HEAVY FINES!
With relatively cheap hi flow Cats available today, there is no good reason to do that.
Old Sep 16, 2008 | 07:54 PM
shamdave's Avatar
shamdave
Old Sep 16, 2008 | 08:19 PM
MK 82's Avatar
MK 82
You and Formula 89 should start a repair business.
Old Sep 17, 2008 | 11:06 AM
shamdave's Avatar
shamdave
but i suck at most repairs Ohio no longer has a emessions check and they only require cars 15 years or newer to be tested.
they did away with it because it did not work.
Old Sep 17, 2008 | 11:13 AM
NEVRL8T's Avatar
NEVRL8T
Old Sep 17, 2008 | 03:35 PM
MK 82's Avatar
MK 82
It's OK. He just changes parts.
Old Sep 17, 2008 | 04:02 PM
shamdave's Avatar
shamdave
what the hell do you do a voodoo chant? does your car fix its self like Christine?
To Test Pipe for Under $20.00!
Old Sep 17, 2008 | 04:53 PM
MK 82's Avatar
MK 82
You mean you don't! What I meant is he just changes parts and hopes with no troubleshooting.
Old Sep 17, 2008 | 05:15 PM
shamdave's Avatar
shamdave
That's why i suck
as mechanic's go , I am a hell of a guitar player
Old Sep 17, 2008 | 06:25 PM
Road Agent's Avatar
Road Agent
That's why i suck
