AFPR worth it?
Old Jan 6, 2002 | 08:38 PM
TexCorvette's Avatar
TexCorvette
St. Jude Contributor
Default AFPR worth it?
Which is the best brand? Will setting it to 40PSI with my mods do much? I hear 40PSI is the best?? had gasket issues when I did this mod on a TPI Camaro. Might want to try it again if its headache free and good results?
Old Jan 6, 2002 | 08:47 PM
AS84's Avatar
AS84
Default Re: AFPR worth it? (TexCorvette)
I don't care for my accel. It does allow you to tune your car for a little more HP. I can't get my pressure below 44 psi on mine. I dunno what the deal is, but I guess its ok because I run mine at 48 psi with good results.
Old Jan 7, 2002 | 10:47 AM
vader86's Avatar
vader86
Default Re: AFPR worth it? (AS84)
Tex, with your mods it might be good to get an AFPR
Old Jan 7, 2002 | 11:09 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I like the HyperTech unit because it takes a wrench for easy adjustment.
Put an ACCEL FP gauge on the fuel rail before you do the AFPR and record the stock pressure reading at idle with vac line disconnected. This will be your baseline setting for the AFPR.
With my mods I'm running 47-48 psi and the air/fuel ratio at WOT is about 12.6-12.8, or 910-920mV at the O2 sensor.
Old Jan 7, 2002 | 04:36 PM
C4-Wolf's Avatar
C4-Wolf
With your mods you might be able to get 5-10 more horses out of adjusting the fuel pressure.
To AFPR worth it?
