can GM eproms be reflashed??
Old Jan 7, 2002 | 03:35 AM
mrvette's Avatar
mrvette
Default can GM eproms be reflashed??
IF so, then rework should be easy, just UV the damn things and reprogramme with an adaptor feeding through the cal pak....NO???
if not, why not???
GENE
Old Jan 7, 2002 | 10:09 AM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
Default Re: can GM eproms be reflashed?? (mrvette)
That's what I do.... erase 'em, then burn 'em.
Old Jan 7, 2002 | 08:17 PM
Rich B.'s Avatar
Rich B.
Yup, that's about it. Most use a modified IDE cable header; Traxions promintro over at DIY-PROM details this.
There's also a thread there right now that gives insight into why some PROM burns fail...It seems that it takes longer to erase a 27C128 via UV each time you burn it...The thread says after as little as 10 burns, it can take over an hour to erase, and it may still fail to limp-mode when in use...
http://www.thirdgen.org/techbb2/show...threadid=75332
Like many others here, I've desoldered the GM EPROM from my MemCal and soldered in a lo-mount ZIF socket, and burn to a 29C256 chip, which is Flash programmable. I choose to "double" my code, so even though the ECM (supposedly) only reads from high memory, I have the lower 128k covered as well.
BTW: Mike Davis estimated that it took 400 burns to get his chip "right on".
[Modified by Rich B., 7:23 PM 1/7/2002]
Old Jan 8, 2002 | 06:36 PM
KYVette90's Avatar
KYVette90
Default Re: can GM eproms be reflashed?? (Marcho Polo)
Can you save the original program in case you need to go back?
Old Jan 8, 2002 | 06:59 PM
Rich B.'s Avatar
Rich B.
Default Re: can GM eproms be reflashed?? (KYVette90)
You pretty much have to. You download your cars binary file through the ALDL (or directly from the MemCal/EPROM) and save it to your HDD. Then you edit it with TunerCat or whatever editor you use. Then save the edited BIN. Then burn that BIN to the new chip (or directly to the MemCal, as Marco said above).
Sounds complicated; but the first time you burn a lower fan temp (the easiest mod) and install it and see it actually *work*, you start feeling pretty confident about it all...
To can GM eproms be reflashed??
