Battery dead? Or alternator...
Old Sep 20, 2008 | 01:57 AM
CStewTAMU's Avatar
CStewTAMU
Default Battery dead? Or alternator...
It's been a LONG time since I have had either go out so I forgot the symptoms.
I got in my vette today and when I turned the key NOTHING happened whatsoever. Not even a clicking sound or anything. No eletrical stuff cut on whatsoever. The PKE didn't work or anything. Absolutely dead-a paperweight. That is a dead battery, right? I figured it it was just "weak" or on it's way out, they symptoms would be different. It hasn't been acting funny, hard starting or anything. I checked the battery connections and they are fine.
Good thing I have another car.
Old Sep 20, 2008 | 02:46 AM
MMOCguy's Avatar
MMOCguy
It sounds like your battery but, to be sure, put a meter across the terminals and see what, if any, voltage you get.
Hope this helps.
Norm.
Old Sep 20, 2008 | 06:47 AM
Churchkey's Avatar
Churchkey
Two things to check:
First clean the battery terminals, corrosion can stop current flow.
When the battery is completely dead its normally caused by a constant current drain. Leaving the interior lights on is favorite.
After servicing the battery terminals hook up a battery charger then check the lights.
A completely dead battery needs to be recharged slowly, suggest a 10 amp charger over night.
There could be other electrical problems however the battery must be fully charged before the rest of the system can be checked.
Old Sep 22, 2008 | 10:40 AM
josephf31's Avatar
josephf31
Default Get it tested
a voltmeter across the terminals won't tell you much as it doesn't produce a load -- bring the battery to a reputable auto parts store and they can test it with equipment that will simulate a load to the battery
Old Sep 22, 2008 | 11:09 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Sounds like the battery is dead. I wonder what people did about dead batteries before the internet?
Old Sep 22, 2008 | 11:19 AM
Iroc57's Avatar
Iroc57
Charged them without a discussion
Old Sep 22, 2008 | 11:46 AM
BADDUCK's Avatar
BADDUCK
Yup, or if it was old just bought a new one.
To Battery dead? Or alternator...
