TV Cable leak....oring or rubber boot ?
Old Sep 20, 2008 | 05:26 PM
Calderone's Avatar
Calderone
Default TV Cable leak....oring or rubber boot ?
Hi,i just installed my trans,and i put back in the tvcable with a plastic cap on the boot,it started to leak.-
I don't remember what was originally there
a rubber boot or just an o-ring ?
i took it away and put the boot plus an oring,the leak is gone but came back in little drops (not always)
what goes there ?
thanks
Old Sep 20, 2008 | 06:55 PM
Frank C's Avatar
Frank C
Calderone; Not sure about Vettes, mine is a ZF but in my 32 that during the 700 install, the TV cable installation can easily cut the rubber seal and then you have to replace it with a new one. Better change it out now to be sure and I usually put some RTV around the dipstick area too.
Hope I'm remembering correctly.............Frank
Old Sep 21, 2008 | 11:52 AM
Pete K's Avatar
Pete K
It is a boot seal. In the US anyway, they are easy to find and cheap.
Check the cable snout for damage when it is apart.
To TV Cable leak....oring or rubber boot ?
