1986 diag port
Old Jan 7, 2002 | 10:20 AM
okinawa86vette's Avatar
okinawa86vette
Default 1986 diag port
Just a quick question, but I can't find the diag port on my 1986 coupe. I must just be missing it. Thanks.
Chris
Old Jan 7, 2002 | 10:40 AM
vader86's Avatar
vader86
Default Re: 1986 diag port (okinawa86vette)
start at your digidash at the corner where it meets the stereo receiver, follow the carpetting STRAIGHT down from the dash and youll see a little black honeycomb looking port, thats the ALDL connector.
Old Jan 7, 2002 | 10:55 AM
scorp508's Avatar
scorp508
It has a black plastic cover over it that you pull straight off.
Old Jan 7, 2002 | 03:36 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Default Re: (scorp508)
Arent them plastic covers like missing in 99% of the cars?
Old Jan 7, 2002 | 03:39 PM
vader86's Avatar
vader86
Default Re: (Bill's86Coupe)
the cover is missing on mine for sure, i didnt even know they had one
Old Jan 7, 2002 | 09:50 PM
UfoPilot's Avatar
UfoPilot
Default Re: (vader86)
I found my cover under my seat when I took out the cusion.
Old Jan 8, 2002 | 05:02 AM
okinawa86vette
Default Re: (UfoPilot)
Cool thanks guys. I did a full ignition system tune up (plugs, wires, cap and rotor), put back on duals (flowmasters) since whoever had the car before swapped it out with a single pipe, what a sin, swapped in a K&N and now the code hasn't come back up. If it comes back up I will be down there getting the codes.
btw, going by the plug part numbers, my car, with the last digits of the vin being 12934, has aluminum heads. I was told by the guys at the Nat Vette Museum that the heads on my car would be iron. Oh well, guess I go a little lucky with the car.
That tuneup sure added a ton of power. The car is much, much better in every motor aspect. It starts quick, theres no hesitation at all and it is much much quicker. No more waiting for the motor to respond, it just rears back and takes off. Feels more like my 97 T/A now.
Chris
Old Jan 8, 2002 | 11:27 AM
vader86's Avatar
vader86
Default Re: (okinawa86vette)
if your number is 12,934 you have cast iron heads, mine is #16,000 and i have iron heads, unless you have a vert anyway
Old Jan 8, 2002 | 05:36 PM
okinawa86vette
I'm pretty sure that it has aluminum heads. The plugs are completely different. I had my father send a set of both plugs because I wasn't sure. Assuming my dad labelled the plugs correctly as to which were for the aluminum heads and which were cast iron, and I verified the plug numbers with the AC Delco web site, it has aluminum heads. The only thing not stock on the car were the rims, horrible centerlines, so I will be looking for new wheels, and the exhaust, so it doesn't look like the heads were swapped. The Japanese don't exactly know how to work on an American engine, let alone able to get parts for it.
I'l do the magnet check and the aluminum head cars have center bolt valve covers, right?
Chris
Old Jan 9, 2002 | 01:15 PM
BBA's Avatar
BBA
All you have to do is LOOK to see if they are aluminum or cast. It's pretty hard to mistake Aluminum heads for cast.
Don't go by the plugs., you could have the wrongs ones in it.
Old Jan 9, 2002 | 02:06 PM
vader86's Avatar
vader86
Default Re: (BBA)
whats your RPO code, do you have KB2?
Old Jan 9, 2002 | 02:23 PM
ADL's Avatar
ADL
Default Re: (BBA)
A quick way to check for aluminum heads is look at the valve covers. if your car has aluminum heads, the bolts on the valve cover will run down the middle of the valve cover.
Old Jan 9, 2002 | 04:17 PM
okinawa86vette
Default Re: (ADL)
I don't know whats up with this motor. The heads used the spark plugs that are listed or aluminum heads, but the bolts on the valve covers ar the old perimeter style. I haven't checked the codes, but I will look.
On a 17 year old car that hasn't had the maintenence and upkeep that it deserves, it is pretty hard to tell the difference. 17 years of grime and oil residue and everything else is on those heads. You guys don't realize how bad the Japanese are about car maintenance. That and being an American car, they don't know how to work on them and are scared to.
Old Jan 12, 2002 | 02:51 PM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
If his sequence # is 12934 he doesn't have an '86 vert.
Old Jan 12, 2002 | 07:16 PM
lowflyer's Avatar
lowflyer
Cruise-In I Veteran
Its too bad you don't live closer to Yokohama. My uncle owns and runs Sato Motors up there, and he does some American car work. I could talk to him and help him along with any questions from this end. I do quite a few L98s and LT1 work at my shop here. Maybe I should move my shop over here:)
With the perimeter bolt valve covers, its a cast iron headed motor for sure. Unless someone has put in aftermarket (AFR, Edelbrock, etc) alum. heads on, but thats probably not likely. Good luck.
Old Jan 12, 2002 | 09:11 PM
okinawa86vette
Default Re: 1986 diag port (lowflyer)
I am about 99 percent sure that my car has iron heads. I wonder why the aluminum head spark plugs were the ones I had to use. I had a set of both from AC Delco, one for the 86 with aluminum and one for the iron heads. The plugs that came out were a match with the aluminum heads. Thinking that maybe they had used the wrong plug last time they were changed, if they were changed, I tried the other ones and they wouldn't even thread into the head. Wierd.
To 1986 diag port
