C4 headers
Sep 21, 2008 | 09:06 PM
C4 headers
I am installing headers on my 85 Corvette and plan to do away with the emmission system. How do I bypass the oxygen sensor and can I do away with the emmission pump. The alternator is mounted to it. Thanks in advance for the help.
Sep 21, 2008 | 09:08 PM
they make a smog pump delete bracket and pulley.. all suppliers sell it. also dumps about 20 pounds of worthless weight.
Sep 21, 2008 | 09:10 PM
if u dont mind me asking... what headers did you go with?
Sep 21, 2008 | 09:36 PM
Quote:
Originally Posted by
BornIn87
I appreciate the help - I went with long tube Headman Headers. Easy to install.
Sep 21, 2008 | 11:56 PM
Buy the AIR delete bracket and use that.
You cannot bypass the O2 sensor, it MUST be installed.
Sep 22, 2008 | 07:59 AM
What vader said. Without the 02 sensor a proper tune is next to impossible.
Sep 22, 2008 | 10:29 PM
vader86
thanks Vader - the headers dont have a place for the 02 sensor, can i put the 02 sensor on the reducer after the header.
Also - what about the air valves that the smog pump attach to - can I remove those too?
Sep 22, 2008 | 10:36 PM
Yes you can put the O2 bung in the collector. If its that far away, it could need to be a Heated O2 sensor (has a 3rd wire to a 12v source).
Anything with the AIR pump can be done away with entirely.
Sep 22, 2008 | 10:45 PM
vader86
My concern is that there is a sensors in the air valve - will I get a check engine light? I also have a vacuum hose going to on of the air valves - just cancel it?
Sep 22, 2008 | 11:33 PM
There are no sensors in the AIR system to cause a SES light.
You can run the vac hose to something else with a T-fitting.
