'89 intermit brake problem
Old Sep 22, 2008 | 08:19 AM
jim davis's Avatar
jim davis
Cruising
Default '89 intermit brake problem
Have a '89 auto vert w/35000 miles, getting an intermit brake pedal to the floor and (not always at the same time) an intermit rumble/thump under the car. I would think the brake pedal is master cylinder related or could the ABS cause both? The sound under the car would make you think U joint but it is intermit. Thanks for any help or expierence you can share.
