700R4 acts strange
I Said to Pete to think to his family first than my trans.
Pete is a friend for me. He made also the best engine I ever had.
I'm trying to understand these problems: (probably someone had the same kind of problem.)
The trans has TransGo shift kit on it.
-Situation: 70 mph freeway, selector lever in OD.
I lift the gas pedal, I move the selector lever from OD to D.
It not backshift from 4 to 3. It stays in 4.
This happens for all speed over 53 mph.
If i apply a small amount of gas pedal (say 10%) it start to gain speed in 4th gear (even if the selector lever is in D)
-It has an hesitation shifting from 2 to 3.
During the shift, it seems that it stay in 2 and when it shift in 3rd , it feels like if it is braking. It's like I have for a while both the gears applied
This happens on part throttle and lately I discovered that it happens also at WOT.-I'm not able to shift manually the gears. It shifts, yes, but if I try to shift at WOT at over 5500 rpm , the shift is very late (too much time to exit from the gear and enter in the next gear).
-Beppe-
It downshifts good doing WOT.
The torque converter locks good and it's a 9.5 unit (3000 stall ).
What I need, is something to start to check.
-Beppe-
" It doesn’t slip or anything but it takes for ever. At the top of second gear you can feel it stop pulling for probably close to a second while it shifts before it sorta enters 3rd, it’s just very slow, not crisp feeling at all. The car actually noses down during the shift, badly enough that I had another driver in the other lane ask me about it, thinking that for some reason I tapped my brakes and my brake lights didn’t come on. "
At part throttle the 2-3 problem is VERY noticeable when the car is cold or during the first times the car performs the 2 to 3 shift.
After 3 or 4 times (and the car is warmed) the 2-3 problem continue to occurs but not so noticeable.
-Beppe-
Probably removing the Valve body and the seperator plate, I can be able to correct the 2 to 3 issue.
What I really have no clue is the 4 to 3 manual downshift problem.
It's quite starnge moving the lever from OD to D and having the trans always in 4.
-Beppe-
you have on upshift 2-3. It felt like I pressed brakes.
I really don't know what that was, it just went away after ~ 1000km.
If I were in your shoes, I would first try to do everything that can be done
without taking the trans off. Take off pan, remove valve body
(be very carefull not to loose some checkballs) and check if separator
plate and both gaskets are alligned correctly.
While you're there, you can remove accumulator housing and remove
1-2 accumulator spring and piston and 3-4 accu. spring and piston
and check that that everything is clean and without any damage.
Do you have service manual?
It could be helpful if you go into this!
Are you speaking about the ATSG Transmission repair Manual ?
About the 2 to 3 shift hesitation-overlap, I studied the transgo kit instructions and the factory manual , and i discovered that the Transgo 2&3 kit wants the hole F plugged AND the hole G a bit enlarged on the separator plate (but still not as large as hole F that was plugged.).
BTW, the Transgo Junior kit wants the hole G enlarged (not so much as the 2&3 kit) and the hole F NOT plugged.
-holes F & G are in parallel with a checkball on hole F-
- 2/4 band push off (hole F)
-3/4 clutch pack applied (hole G) .
I really don't know if Pete, used both kits or only the 2&3 reprogramming one.
-Beppe-
