1993 corvette coupe passenger door pull
Old Sep 22, 2008 | 02:23 PM
PHILLY JOE's Avatar
PHILLY JOE
PHILLY JOE
Default 1993 corvette coupe passenger door pull
This car is mint only 22k but is there a wat to tighten the passenger sidedoor pull screw without taking off the door panel. Thanks
Old Sep 22, 2008 | 04:30 PM
bikertrash2001's Avatar
bikertrash2001
You need to pull the panel to get at the screw. Pulling the panel is a little tough the first time, just make sure you get all the screws around the door latch/handle and slide lock. You'll be a pro at it the second time
That screw will pull out of the plastic if you don't get it taken care of.
Old Sep 22, 2008 | 08:05 PM
PHILLY JOE's Avatar
PHILLY JOE
PHILLY JOE
Originally Posted by bikertrash2001
you need to pull the panel to get at the screw. Pulling the panel is a little tough the first time, just make sure you get all the screws around the door latch/handle and slide lock. You'll be a pro at it the second time
that screw will pull out of the plastic if you don't get it taken care of.
thanks for all your help
To 1993 corvette coupe passenger door pull
