fuel pump relay location
Old Sep 23, 2008 | 08:55 PM
ram0672's Avatar
ram0672
Default fuel pump relay location
Can someone tell me where the fuel pump relay is located on a 94.
Old Sep 23, 2008 | 09:38 PM
formul89's Avatar
formul89
Under the passenger side dash kick panel. There is a black box just ahead of the metal plate. You do not have to remove this plate.
There are 4 relays. There are two in tandem in the middle. The fuel pump relay is the one towards the front of the car.
Old Sep 24, 2008 | 09:40 PM
ram0672's Avatar
ram0672
Thanks for the response. Do I remove the lower part of the dash to get access to the black box?
Old Sep 25, 2008 | 12:08 AM
formul89's Avatar
formul89
Yes. Pop out the little center piece in the dash vents to access the torx screws to be able to remove the lower kick panel.
To fuel pump relay location
