Hood release cable / handle problems !!!!!!!
Old Sep 25, 2008 | 08:49 AM
Calderone's Avatar
Calderone
Default Hood release cable / handle problems !!!!!!!
Damn,i knew it
since days ago,the release handle has a "loose" feeling
until yesterday,it won't open,i had to take it off and leave the cables alone,and open the hood,pulling the cables themselves
one of the little retaining "heads" of the cables is broken,and the crossbolt that holds the hood release handle is loose,i don't know what's the problem,the handle or the cables (with no head)
i want to get it together soon,and i forgot the "emergency" cable release solution that we had posted here on the board with 2 plastic clamps.-
thanks ! any ideas ?
Old Sep 25, 2008 | 10:23 AM
VETTEHIGH's Avatar
VETTEHIGH
I had the same problem. My builder fixed it with a new hood handle. Believe your problem is with the hood release handle
Old Sep 25, 2008 | 10:30 AM
Calderone's Avatar
Calderone
Yes i guess so
but the cable "heads" are gone
Old Sep 25, 2008 | 12:45 PM
Tom Piper's Avatar
Tom Piper
About a year ago, I bought a new GM hood release cable for my '92.
The new cable has a diameter that is thicker than the old one that I had -- hopefully, that means it will last longer.
Tom Piper
Old Sep 25, 2008 | 01:31 PM
Slalom4me's Avatar
Slalom4me
Originally Posted by Calderone
... since days ago,the release handle has a "loose" feeling
until yesterday, it won't open,
Any ideas ?
Does anything in the following link help your situation?
Old Sep 26, 2008 | 09:08 AM
WW7's Avatar
WW7
The first thing you have to do is install the little cables on the releases so if you have problems with the cable you can still get your hood open..I put them on my 89 and it only took 20 minites, now if a cable brakes all I have to do is pull the wires and the hood opens right up....
Old Sep 26, 2008 | 09:31 AM
NEVRL8T's Avatar
NEVRL8T
Old Sep 30, 2008 | 12:15 PM
Slalom4me's Avatar
Slalom4me
I don't know what's the problem, the handle or the cables (with no head) Any ideas ?
Any success?
Old Sep 30, 2008 | 12:33 PM
Calderone's Avatar
Calderone
Hi Slalom,i've been busy installing new Bosch III injectors,thermostat and o2 Sensor
but i will give it a try asaic,none of the cables are broken,i think the head is repairable,
i will try to reinstall them on the handle again and will tight the cross bolt.-
To Hood release cable / handle problems !!!!!!!
