Replace the POS battery terminal bolts
Old Sep 25, 2008 | 12:56 PM
steve mulherin's Avatar
steve mulherin
Default Replace the POS battery terminal bolts
Where can I get replacement battery bolts with large heads? NAP did not have them. The GM bolts with the tiny heads are junk.
Old Sep 25, 2008 | 01:31 PM
l1sikes's Avatar
l1sikes
The stock bolts are configured to pass through the cable's end boot.
Replace with stock bolts, they will work fine if you use only 6-point sockets on them - no 12-point or open-end wrenches.
Old Sep 25, 2008 | 01:35 PM
rickneworleansla's Avatar
rickneworleansla
They are junk. I believe I replaced mine with a standard side post fitting from autozone.
Old Sep 25, 2008 | 07:36 PM
rons85's Avatar
rons85
You really don't Want anything you can really tighten - the threads are into Lead. Not the Strongest of materials...
Be aware too - if you Do replace the bolts with something you shouldn't, make absolutely certain that the new bolts don't reach any further into the battery than the Old ones do. If the new bolts are too long they will break thru out the Inside of the lead fitting and allow acid to seep past the threads, and to splash against the inside end of the bolt. The life of the bolt when that happens is a matter of Weeks, before it dissolves away and the cable falls off the battery... Been there, done that.
Of course you Could find 316 or 303 stainless bolts.. hardware 304 stainless (really 18-8, but close enough) will last better than mild steel, but not forever
Old Sep 25, 2008 | 07:45 PM
Road Agent's Avatar
Road Agent
Your spot on! The small stock bolt heads are to keep Gorillas from stripping the threads!
Old Sep 25, 2008 | 08:09 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Get a wrench that fits and use stock bolts.
Old Sep 25, 2008 | 08:10 PM
Aardwolf's Avatar
Aardwolf
I learned that lesson when I first got my car. I ended up buying a better socket then my 12 point and stopped using a wrench. I replaced the worn bolts with the same thing bought from NAPA.
To Replace the POS battery terminal bolts
