Need help...
Old Sep 27, 2008 | 02:14 PM
pearlvett's Avatar
pearlvett
Default Need help...
I want to build a 383 stroker that is pushin 500hp and 525-550tq with all forged internals. Im not knowledgeable enough to figure out what the best combos would be and stuff like that. I have an 85 and im planning on using the stock block. Input from the experienced engine builders would be appreciated.
Old Sep 27, 2008 | 03:53 PM
pearlvett's Avatar
pearlvett
bump
Old Sep 28, 2008 | 09:21 AM
Pete K's Avatar
Pete K
Bump to the top for you.
Part of the reason you may not be getting replies is because there are many, many cars on the forum running similar packages. If you search, you will find alot of reading. My car has a 383 with approx 380 hp and 440 ft lbs, so I would not use my example.
To Need help...
