Third O2 Sensor on a 95?
Old Sep 29, 2008 | 01:35 PM
LTxDave's Avatar
LTxDave
Default Third O2 Sensor on a 95?
What does the third O2 sensor on a 95 do? I keep getting a code for a lean condition on the RH side O2 sensor and the car is loading up like the PCM is adding too much fuel. I could not find any codes published that relate to the second sensor on that side, so I'm wondering what the PCM uses it for.
Old Sep 29, 2008 | 02:30 PM
STL94LT1's Avatar
STL94LT1
The third o2 sensor on the 94-95 cars is pretty much useless, and won't throw a code.
Old Sep 29, 2008 | 09:42 PM
Eddie & the Cruisers's Avatar
Does that mean I can use the third one to swap out either of the primary ones, if bad, and save a few bucks?
To Third O2 Sensor on a 95?
