HELP: Valve stem o-ring or not !!
Old Sep 29, 2008 | 03:08 PM
rjdavis21's Avatar
rjdavis21
2nd Gear
Default HELP: Valve stem o-ring or not !!
Im replaceing valve stem selas on my 86 vette and local machine shop said to use umbrella type on exhaust and positive seal type on intake . I called them back and asked about the oem o-ring on the stem under the keepers and they said I culd put one back or leave it off what do you think, does this sound right. I have read forum but have not found this question .
Old Sep 29, 2008 | 08:54 PM
John A. Marker's Avatar
John A. Marker
Most of us that have replaced the seals use the FELPRO intake seal all the way around. The umbrella seal on the exhaust just doesn't last. I replaed the "O" rings (they came with the seals). Just be careful when you install the seals, there should be a clear plastic sleeve with the seals that slips over the end of the valve stem. This is used to protect the seal from being cut by the groove used for the "O" ring. Slip the sleeve over the stem, dip the seal in some clean engine oil and slide it over the sleeve and down the stem and push it down tightly. Use the sleeve to start the "O" ring, then pull of the sleeve and seat the "O" ring in its groove. Use the sleeve on the next valve stem.
You might check out the post from Joe C about his alternative method of adjusting the valves. This works well and takes the guess work out of the zero lash adjustment.
Old Sep 29, 2008 | 11:13 PM
Qiken's Avatar
Qiken
Old Sep 30, 2008 | 12:07 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The '85 and early '86 (iron heads) used a "rotator" on the exh so the seal differs from later Al heads.
When I did seals I got OEM style, including the O-rings from a local Chevy dealer to avoid any future issures...
Old Sep 30, 2008 | 07:13 PM
rons85's Avatar
rons85
Without the positive seals (or umbrellas) you Need the O-rings on there.. With good seals the o-rings serve little or no purpose - I leave em off..
To HELP: Valve stem o-ring or not !!
