LS to ZF
Old Sep 29, 2008 | 08:33 PM
COPO's Avatar
COPO
Default LS to ZF
Been reading all the posts on this. Mcleod is suppose to be making a bellhousing, but was bought out and i have heard nothing about if they plan on finishing one. Also read that adaptor plates are on the way, but heard nothing else. If any one knos of any thing in the works it would be very helpful. I want a LS in my c4 so bad that i pulled out a zf core and been doing sum measuring. Talked to the machinist at work and and have a few ideas rolling around. Looking at having a bolt in kit for a LS in a c4 using a zf with motor mounts. Use the stock LS cultch and all the c4 factory clutch position.
If nothing eles is out there i will persue this with the intent to be a bolt in kit other than crossmember mods for the balancer. It makes me sick that there are kits to put a LS in a miata but not our beloved c4. I have most of the measurments and it is very doable and be realtive simple for the average person to install. I am not making any promises that it will work out as i have planed, but im not that far away.
So how many I DO'S would be in for a kit that mounts a LS to a ZF with motor plates?
Old Sep 29, 2008 | 09:05 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
I would be very interested in doing this to my car, mainly because it looks like it would be cheaper for the same amount of performance. I have a hard time justifing spending 10 to 12 grand on a new engine for a car worth 6 or 7.
Old Sep 29, 2008 | 10:32 PM
Mojave's Avatar
Mojave
I would love if someone was able to make this work, as it would really make the LSx C4 so much easier to do.
Old Sep 29, 2008 | 11:01 PM
mechguy79's Avatar
mechguy79
I'm game, especially when you can get the LQ truck blocks much cheaper than LS's.
Old Sep 29, 2008 | 11:08 PM
Zix's Avatar
Zix
One main issue is that the LS flywheel is larger in diameter then the ZF unit so it won't fit under the ZF bell housing. If you make an extension for the bell housing then there is a problem with the input shaft being too short. Now you could convert your transmission to a ZR1 long shaft but that's not cheap to do!
Or you could manufacture a whole new bell housing...but that's not going to be cheap either.
Old Sep 29, 2008 | 11:20 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
Good luck I would love to try the swap
Old Sep 29, 2008 | 11:21 PM
COPO's Avatar
COPO
yep this is a lot of difference. Hope I dont wind up with an answer that requires a NEW bell housing.
Old Sep 30, 2008 | 07:10 AM
Mr6spd's Avatar
Mr6spd
There is now a LS to ZF bellhousing available !!!
http://www.quicktimeinc.com/products.html
Old Sep 30, 2008 | 08:26 AM
-=Jeff=-'s Avatar
-=Jeff=-
Wonder how much it moves the motor around. I saw that Bellhousing too..
That would be very nice if it works well
Old Sep 30, 2008 | 10:34 AM
Mojave's Avatar
Mojave
Very, very interesting. I wonder if this would work with the LSx C4 motor mounts and headers. I would hope this keeps the trans in the same place so the stock c-beam will work, but it seems unlikely that it won't move some.
Old Sep 30, 2008 | 03:42 PM
Zix's Avatar
Zix
Anyone have an idea on the price of the bell housing?
EDIT: I found it, $450...not too bad
Old Sep 30, 2008 | 07:16 PM
COPO's Avatar
COPO
called them today and yes it is 450 plus s/h. the only concern i have is which zf it is for. Ross(owner) did not kno that there are 2 zf's. didnt have a clue about the input shafts. but it does keep it in the same place. He also said its been a good seller as they have sold bout 30 of them. SO WHERE THEY AT? I dont kno how speedhound motor mounts position the engine, but the plates we have at work should be able to be used to bolt in the L98 cars. So that thankfully puts a end to me tring to work with the bell housing and adaptor plates i had in mind. I was bout 4 hrs away from having it mounted..lol. I plan on ordering one in a couple weeks and see what its all about. If any one has one or gets one before i do speak up and share some info. It will be good info for the 6 spd guys.
Thanks Mr6spd for the link!!!!!!!1
Old Sep 30, 2008 | 07:46 PM
Zix's Avatar
Zix
I would highly doubt they made it for the ZR1 long-shaft, as they are pretty hard to come by. Like everyone else I'm just curious if it keeps everything in the same spot, the C-Beam being the key.
Old Sep 30, 2008 | 08:05 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
This is some good news
Old Sep 30, 2008 | 08:58 PM
Ryan59's Avatar
Ryan59
RM-6039SFI Certified @ 6.1
RM-6039 - LS-1 Bellhousing to ZF Transmission - NEW!
* Height = 5.775
* Trans. Bore Ø = N/A
* Engine = Chevy LS-1, LS-2, LS-3, LS-6, LS-7, LS-9, Small Block Chevy, Big Block Chevy, LT1
* Trans. = GM ZF
* Flywheel = 168 or 153 tooth
* Weight = 22#
* Block plate, engine bolts, and shifter fork ball included
Old Sep 30, 2008 | 11:08 PM
lltrevino's Avatar
lltrevino
I may have a different approach to my winter project,,,, can I say 5.3??!!!!! so many perfomance parts available, that make th hp they claim!!!!!!!
Old Sep 30, 2008 | 11:22 PM
C4forlife's Avatar
C4forlife
Default how about this?
how about a new tailshaft that would replace the stock T56 tailshaft to make a sweet ls/T56 swap without alot of other custom parts.
To LS to ZF
Old Sep 30, 2008 | 11:29 PM
COPO's Avatar
COPO
more than likely it is for the short shaft. Claims the trans does not move. Just a bell housing like all the others that have been made over the yrs. I'll kno in a couple weeks.
Old Sep 30, 2008 | 11:33 PM
COPO's Avatar
COPO
I think most want to keep the ZF and just do a motor swap. If the bellhousing keeps the trans in the same spot it would be a lot cheaper to just do a motor swap.
Old Sep 30, 2008 | 11:38 PM
COPO's Avatar
COPO
5.3 are cheap..but the 6.0 are getting reasonable now.
