extrude honing....where and how much?
Old Oct 1, 2008 | 02:24 PM
1990dtgL98's Avatar
1990dtgL98
St. Jude Donor '10-'11-'12-'13-'14
Default extrude honing....where and how much?
So, you guys thankfully pointed out a bottleneck in my buildup.
The heads I bought flow 280cfm and I plan on using the superram manifold and runners to get that nice mid-range hump or torque.
However, the superram only flows 240cfm...so instead of trying to sell it and by a miniram (which would be easier to work on, but also does not have EGR), I think I might extrude hone the intake and runners.
I was just wondering if anyone had an idea of the "after" flow numbers? Is there an average extrude honing gets you? Say 30cfm or something?
Also, would it be better to extrude hone the superram or have it professionally ported? Can the runners be ported or extrude honed?
Trying to get ideas to not have a bottleneck.
Old Oct 1, 2008 | 02:51 PM
formul89's Avatar
formul89
Extrude hone = $$$$$$$$$$
It works well, though.
Old Oct 1, 2008 | 03:01 PM
cv67's Avatar
cv67
St. Jude Donor '05
Depends how long they run the stuff through, I have heard they can use a more agressive material in the mix if you want to get more gains.
Pricy but porting a TPI base is a royal pain and takes forever to do it right.
Old Oct 1, 2008 | 03:02 PM
pologreen1's Avatar
pologreen1
I see you are keeping it now! probably a good idea! I am crossing my fingers on the bbk price and availability!
Old Oct 1, 2008 | 04:19 PM
Bad Karma's Avatar
Bad Karma
Here's their site, prices listed within.
http://gethoned.com/
Old Oct 1, 2008 | 05:54 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
I emailed around May and asked this question. Bases are nearly $400 to hone! The reason was because of a two steps process required to hone a base". However, runners were about 1/2 that @ $200ish.
They said to expect about 10% improvement in flow. I asked if additional material could be removed. They said no.
240*1.1=264cfm
So about $600 + round-trip shipping would still leave you short of 280cfm. Another thing to consider is that intakes should be sized 15% larger than head-flow. (Reason being that parts flow less when combined in "chain".)
That means you might want an intake that flows about 300cfm to be "optimal".
BTW: Do you have a stock base or large-tube base?
Old Oct 1, 2008 | 09:27 PM
RiktorD's Avatar
RiktorD
They should be able to hone the entire assembly with the runners bolted to the manifold.
Old Oct 2, 2008 | 12:25 AM
1990dtgL98's Avatar
1990dtgL98
Tempted to. I was considering switching and I still am. Thing is, I have the superram, so unless I can get a great deal on a miniram, it's hard to switch. Im sure if I had a miniram and was thinking of a superram, it'd be reversed.
240*1.1=264cfm
I have a Accel high flow base with it.
Old Oct 2, 2008 | 01:09 AM
GREGGPENN's Avatar
GREGGPENN
I wonder if you're underestimating the resale value of a superram. I suspect you could get most, if not all the money you'd need to buy a miniram. Moreover, I'm certain the cost of honing -- added to the resale value of your SR would EXCEED the cost of a miniram.
IOW, the mini would cost less than honing (assuming you didn't keep your superram).
In case you haven't checked SR's are going for $1,200 used (base, runners, and plenum). Since you can't buy one new, people will pay the same for used. How's that grab ya?
Old Oct 2, 2008 | 07:45 AM
USAsOnlyWay's Avatar
USAsOnlyWay
http://www.thirdgen.org/techboard/al...fications.html
Do that and your intake won't be the weak point anymore. Also, if you can find someone to do that and do it well. Let me know...
Old Oct 2, 2008 | 10:52 AM
1990dtgL98's Avatar
1990dtgL98
I know I could probably get most of my money back...I meant more the hassle of selling it, boxing it and shipping it, then finding a miniram and having that shipped to me...
Dear lord...If I did that, I probably wouldn't have a superram to sell!
Old Oct 2, 2008 | 11:22 AM
cv67's Avatar
cv67
St. Jude Donor '05
Too bad you cant see the pics without logging in. Would be nice to have a Bridgeport laying around.
Old Oct 3, 2008 | 02:56 PM
1990dtgL98's Avatar
1990dtgL98
Ok, here's a branch off the main question.
Lets say I kept the superram. How much power and tq would I make if I only spun the motor to 6k? Now, lets say I bought a miniram. How much power and torque would I make if I only spun the motor to 6k?
See what I'm saying? If the superram flows "only" 240cfm and the miniram flows 290 cfm or there about....but I loose low and mid end torque to the miniram, and only gain, say 20 hp because I'm going to be shifting at 6k....would it be wise for me to switch?
Basically, what I mean, is: do the flow numbers mean much? If a more restrictive intake makes more power where I want it, shouldn't I look at that and not the numbers?
Old Oct 3, 2008 | 04:23 PM
arandy's Avatar
arandy
St. Jude Donor '08
It is nice. Especially when it is sitting next to the Hardinge.
To extrude honing....where and how much?
