Need some exhaust recommendations
Old Oct 1, 2008 | 06:00 PM
lone73's Avatar
lone73
Default Need some exhaust recommendations
I have a '96 LT4, R/H cat is bad. I want to replace both with preferably a high flow cat. I have looked at the magnaflow's but they are apparently ceramic insides and don't last long. They also require fabrication for a '96 as no direct fit cats are available. Rather than pay someone $300 labor to fabricate pipes to install universals I thought maybe there were some headers that were available that I could just clamp some cats to and in so doing put the labor money into some headers. The rest of my exhaust system is in decent shape and I don't want to blow a huge amount of money on it. I would like to get out for under $700 for headers and cats if possible.
thanks
Old Oct 1, 2008 | 06:09 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
thanks
Ceramic is fine for cats.
Old Oct 1, 2008 | 06:55 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
Two years ago I took my 95A4 and put Stainless works LT headers & RT hiflow stainless cats on but kept the stock exhaust and have been very happy with it. The headers give the exhaust a much deeper sound and it sounds really nice.
The package however is more than you are looking to spend. There was a group purchase that I participated in and I think that it was close to $1200 for the whole package and that did not include installation.
Old Oct 2, 2008 | 11:54 AM
RogerZ06's Avatar
RogerZ06
Magnaflow makes A1 product, Can't go wrong there
Old Oct 2, 2008 | 05:43 PM
93lt1fun's Avatar
93lt1fun
Try Random Technology http://www.randomtechnology.com/
They sell stock and performance CATS. I have 3" bullet cats on my '93 and they work great!
P.S. Ceramic is the standard material used in ALL CATS.
Old Oct 5, 2008 | 11:39 AM
lone73's Avatar
lone73
Have any of you that used long tube headers and high flow cats had any problems with the check engine light coming on?
A guy at HottExhaust.com told me that sometimes cars will flow too much with headers and never reach light-off temp (whatever that is) for the cats. Then the check engine light will come on. It can also be caused by the cats being too far downstream from the motor allowing too much cooling before the exhaust reaches the cats.
If you've seen that prob, what did you do to get around it?
thanks
Old Oct 6, 2008 | 06:15 PM
93lt1fun's Avatar
93lt1fun
thanks
Yes, this is a known issue with headers. Exhaust temp, typically 600+, is not reached with non-heated O2's. The fix is heated O2's, however, I'm still getting an intermittent Check Engine light but, haven't done the diagnostic to figure out which O2 is the source. There are aftermarket heated O2 kits which I have installed that have the heated O2's and wiring harness. Some examples:
http://www.casperselectronics.com/mm...ry_Code=CORVC4
http://cgi.ebay.com/ebaymotors/TPI-L...QQcmdZViewItem
http://www.thunderracing.com/catalog...vid=11&pcid=54
Old Oct 6, 2008 | 06:35 PM
LT4BUD's Avatar
LT4BUD
thanks
I have high flow cats (3") and EM long tube headers...no problem
To Need some exhaust recommendations
