Bosch Oxy heated 4 87 ??
Old Oct 1, 2008 | 08:11 PM
loaded vet's Avatar
loaded vet
Default Bosch Oxy heated 4 87 ??
I have been looking all over for a heated Bosch Oxygen sensor that is designed for the 87 L98 .45 volt crossover. Also where is the best point to take the 12 volts?
Thanks,
Gary
Old Oct 1, 2008 | 09:33 PM
C409's Avatar
C409
Default O2s
I used one for a 90 ZR1 on my '87.....wired a relay off the connector 'tween the battery & firewall for heat part.....and off the ignition feed to the distributor to turn the relay on/off.....mounted my relay next to the cooling fan relay under the master cylinder on the inner fender.....good luck
Old Oct 2, 2008 | 09:11 AM
loaded vet's Avatar
loaded vet
Thanks C409. Good suggestion.
Gary
Old Oct 2, 2008 | 12:13 PM
Calderone's Avatar
Calderone
what's the difference with the normal one ?
Old Oct 2, 2008 | 03:00 PM
C409's Avatar
C409
Heated comes on quicker for closed loop operation......highly recommended for long tube headers when you mount O2S in the collector.....heater helps keep it on at idle .....also good for bigger injectors and/or cams.....closed loop gives the best fuel economy and efficiency for driving in traffic.....WOT is still according to the tuner
Old Oct 2, 2008 | 03:11 PM
Calderone's Avatar
Calderone
thanks for the info
everyday you learn something new
let us know when you get it !
Old Oct 2, 2008 | 06:22 PM
the blur's Avatar
the blur
actually closed loop doesn't come on any sooner, as there is a timer in the PROM, plus other variables that control closed loop.
tpiparts.net sells a kit that I used on my 89.
Old Oct 2, 2008 | 07:15 PM
MK 82's Avatar
MK 82
Why don't you tell us all the conditions for entering closed loop on an 87!
Old Oct 2, 2008 | 07:36 PM
larryfs's Avatar
larryfs
coolant temp is one.
the timer.
the o2 sensor temp for sure.
plus there may be others conditions...........
go to 3rd gen f body site.
they'll know for sure.
Old Oct 2, 2008 | 07:51 PM
MK 82's Avatar
MK 82
So a Camaro site would know the conditions for establishing open loop on a Corvette?
the timer.
Old Oct 2, 2008 | 08:12 PM
larryfs's Avatar
larryfs
for OBD1 prom information, 3rd gen .org is the place to go.
TPI motor's are all basically the same.
To Bosch Oxy heated 4 87 ??
By Michael S. Palmer | 2026-06-03 09:39:05
