Has anyone had experience with replacing your directional bulbs with LED's? I replaced my 3rd brake light and rear tail/stop with LED bulbs. I also replaced the flasher with an electronic one. They worked great. i purchase the same bulbs but in amber for the front parking/directionals. This where it went sour. Th efront bulbs hardly light and the directionals no longer work. If I go back to original bulbs up front then all is well. Has any body had the same experience and figured out how to fix it? I did the same thing to my 1996 Impala SS and had the same results. Any help would be appreciated. THANKS
Seen that is an old thread, but i have some peoblem here
LEDs generally have certain polarity, as they only go in one way for them to work. At least older leds did. If its a plug in, flip it inside housing.
Remember, its a light emitting diode. Power goes one way, with only the zener diode going the other way. Powrr flows egative to positive. If its in backwards, no light.
