LT4 Overheating Question
Old Oct 6, 2008 | 09:02 AM
dlt4's Avatar
dlt4
Originally Posted by 73, Dark Blue 454
Have you ever introduced any of the "stop-leak" products to the cooling system?
Never have.
Old Oct 6, 2008 | 09:24 AM
dlt4's Avatar
dlt4
Originally Posted by pr0zac
my car had very similar problems. my car blew a head gasket at like 93k. i think the previous owner had a little too much fun with nitrous. but it had made a small crank in my radiator that wouldn't drip cause it was high enough on the radiatior the coolant would evaporate before hitting the ground. for quite a while i thought that i had another bad head gasket or something wrong cause i could smell the coolant and after blowing a radiator hose and replacing the waterpump (that also started leaking) i finally had enough pressure in the system to show a leak. some ideas to look into.
Your comment about smelling the coolant is interesting. When the problem first started I did smell coolant when I parked the car. I looked and looked for leaks, but never saw any. Now the coolant smell has gone away.
Old Oct 6, 2008 | 09:30 AM
dlt4's Avatar
dlt4
Originally Posted by GM_96LT4
A couple of questions; is the car overheating while you are idling only or all the time?
Interestingly enough, yesterday when I just let it sit and idle, it went up to 228, both fans kicked on, and the temps came back down. I didn't let it run for a long time after that, so I'm not sure how low they went.
If the car keeps cool while running; I would look at the fans. I had problems with both fans, more specifically the fan motors.
That's when it gets up in the 230s, but it doesn't stay there. It fluctuates up and down.
Also, make sure your front air dam is in good condition and that their is no junk in front of the radiator.
Checked that!
One last thing is to check that the fan shroud is in good condition. Most people won't experience this problem; but I had to cut my shroud when I put in a Be-Cool Radiator and accomodate the extra thickness of the radiator and my supercharger. I ended up going back to the stock radiator.
Anyway, good luck.
Glenn
Thanks for the tips.
Old Oct 6, 2008 | 09:33 PM
lt4obsesses's Avatar
lt4obsesses
Actually after reading the last post, it sounds like a perfectly normal LT4 to me.
Old Oct 6, 2008 | 09:34 PM
devildog's Avatar
devildog
From: fighter pilots make movies, bomber pilots make history
Originally Posted by dlt4
Never have.
Use the Barrs tablets, same thing as the GM parts counter tablets.
Most all GM cars and ALL Corvette have this added at the FACTORY. It is part of the recommended procedure in the field service manual when a flush is performed.
Joe
Do the pressure test to look for leaks that can be corrected mechanically, tablets or liquids with suspended particles seal micro leaks.
Old Oct 8, 2008 | 08:25 PM
dlt4's Avatar
dlt4
Turns out the radiator has a crack in it. I guess it was never big enough to notice until last night when it became real noticeable. I hope that's the only problem. I'll know after tomorrow.
Thanks to all who posted comments.
Old Oct 10, 2008 | 08:51 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Joe
FYI, I believe GM recanted their manual recommendation to add the tablets in a later service bulletin -- so consider carefully what the tablets do (clog things on purpose) before using them.
Old Oct 10, 2008 | 10:17 PM
devildog's Avatar
devildog
Thanks for update on the use of those tablets. I never liked them, prefer using the Bar's suspended aluminum particle sealant in my older Corvettes. Did have success on my 95 with a small head exhaust gas leak using a fine particle 'nano' sealant.
Joe
Old Oct 10, 2008 | 11:35 PM
larry00's Avatar
larry00
Joe
I'm going to replace my radator on my Stock 95 unless I pull it and there is stuff between the condenser and the radator.
I will also add water wetter when I recharge w/antifreeze which I might add needs replaced every three years.
Burping is important as a little air can keep the liquid from flowing.
My Hot Rod 95 LT 4 has a new radator and never overheats.
These Aluminum Radiators need replaced as they stop working right when they get corroded with time.
No need for high dollar the HD stock is fine.
Old Oct 10, 2008 | 11:49 PM
Gonzo's Avatar
Gonzo
alot of good info here, shows why diagnosis is so difficult
Let us know if that solved the problem
Old Oct 11, 2008 | 09:44 AM
dlt4's Avatar
dlt4
AND - a blown head gasket!
Old Oct 11, 2008 | 09:51 AM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Ouch! Time for a stroker?
Old Oct 11, 2008 | 09:57 AM
  #33
lt4obsesses
Oh man, that's no good. Perhaps make a good thing out of it...port & polish those LT4 heads while they're off?
Old Oct 11, 2008 | 02:24 PM
  #34
dlt4's Avatar
dlt4
That's a thought, but it will depend on the cost.
Old Oct 11, 2008 | 02:47 PM
  #35
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Id say youre VERY close to being there just by pulling the heads.
Old Oct 12, 2008 | 12:00 AM
  #36
dlt4's Avatar
dlt4
I've never had a car with ported and polished heads. Would it make a noticeable difference in performance. Not a difference in the ET slip, but a seat-of-the-pants difference?
Old Oct 12, 2008 | 12:03 AM
  #37
Pete K's Avatar
Pete K
Done correctly, Yes
Old Oct 12, 2008 | 09:27 PM
  #38
lt4obsesses
From the research I've done, as I understand it. GM put extra material in the LT4 heads and added a smaller cam to reduce the out put. I forgot where I read it but with the originally intended cam (LT4 Hotcam) and original head configuration, the LT4 put out over 400 ponies. GM had to scale it down so people would buy the LS1 coming out the following year.
The heads will probably need some machining anyway, so the porting will probably not add that much to the bill.
