Carb for 88 with 383stroker
Old Oct 5, 2008 | 10:14 PM
alanterhk2's Avatar
alanterhk2
Default Carb for 88 with 383stroker
Does anyone have part # for a intake and carb that will fit a sb 383 in a 88 vette without having to modify the hood
Old Oct 5, 2008 | 10:19 PM
pr0zac's Avatar
pr0zac
miniram or superram depending on the cam and heads. :-)
Old Oct 5, 2008 | 10:25 PM
cv67's Avatar
cv67
St. Jude Donor '05
What all have you done to the motor internally?
Diff. gear? Auto, stick?
Old Oct 5, 2008 | 10:44 PM
alanterhk2's Avatar
alanterhk2
Its 383 with very mild cam to work with TPI and for mileage,headers.Right now it has all factory TPI ported to with an Edelbrock intake for the TPI. 58mm throttle body and chip burn for cam and rear gear which is factory.It is auto 700r4 built for motor
Old Oct 5, 2008 | 10:47 PM
alanterhk2's Avatar
alanterhk2
If i wasnt sleeping I would of mentioned it has AFR heads with 190/210 i believe
Old Oct 5, 2008 | 11:08 PM
Corvette Chris's Avatar
Corvette Chris
Slap on miniram on that sucker.
Old Oct 5, 2008 | 11:15 PM
alanterhk2's Avatar
alanterhk2
any particular brand or part #
Old Oct 5, 2008 | 11:20 PM
pr0zac's Avatar
pr0zac
if you have a small cam, a decent base and ported runners and plenum i would imagine that you wouldn't really see a gain worth writing home about going carb.. maybe a gain in your average gas bill. and a large loss in your wallet with a sad look on your face.
Old Oct 5, 2008 | 11:28 PM
Corvette Chris
TPiS www.tpis.com
1205 ought to work nice.
Old Oct 5, 2008 | 11:37 PM
pr0zac's Avatar
pr0zac
ok so my first post was a bit of joking around. but seriously i doubt that you wil see any real gains switching manifolds and you would probably have a heartattack seeing the prices of your options. maybe some runners tops but you haven't really given any details of the cam nor do you know what size your heads are. if you have 210's then a miniram would probably be in order if you really are going to stay fuel injected which many would suggest. if you have the older 190's maybe a superram plenum and runners would do the trick.
Old Oct 5, 2008 | 11:42 PM
alanterhk2's Avatar
alanterhk2
I guess before I waste all time I need to pull spec sheets out and see exactly what I got.Memory is not as good as it used to be.I will be back! Thanks for the info!!
To Carb for 88 with 383stroker
