Power Window Help Needed
Old Oct 7, 2008 | 01:38 PM
Biker's Avatar
Biker
Default Power Window Help Needed
The passenger side window in my '86 vert goes down halfway and stops. If I nudge the glass, it goes down fully. Any idea what's wrong and the fix?
Old Oct 7, 2008 | 01:55 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I understand that year employs some kind of "ribbon" in the window lift, which can go bad and cause problems. There are replacement ribbons available as well as conversion kits to the newer style window lifts, i.e. sans ribbon.
Open up the door panel and see what is up in there.
Old Oct 7, 2008 | 02:28 PM
reoch999's Avatar
reoch999
Open it up and have a look. Run it up and down a few times and see what you see. And Ecklers will probably have the parts if you need some.
To Power Window Help Needed
