vortech v1 supercharger
Old Oct 8, 2008 | 10:35 PM
minimike96's Avatar
minimike96
Cruising
Default vortech v1 supercharger
hey guys!!!
just got a newly used vortech v1 charger and not sure if it will work on my 1994 corvette, does it go on the pass side. driver? does anyone have pics of a vortech on a c4 corvette? i need help!!!!!!!
Old Oct 9, 2008 | 03:16 AM
qwiketz's Avatar
qwiketz
does it have a curved or straight discharge? If it has a curved discharge, it'll only work using the carroll brackets. If it is straight then you may be able to use the vortech brackets assuming it's not a straight discharge clockwise blower. You need counter clockwise straight volute for the vortech brackets. Call vortech and ask using the serial #.
Old Oct 9, 2008 | 01:36 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Does it look like this?
http://www.vortechsuperchargers.com/...101&cat_key=12
Old Oct 11, 2008 | 06:30 PM
minimike96's Avatar
minimike96
Cruising
ok, so i figured out that my unit came off a lt1 camaro so it will only work if i make the brackets myself, not a problem, thanks
and no. it doesnt look exactly like that picture, same thing but backwards, ill post a pic once i get it mounted
Old Oct 11, 2008 | 10:07 PM
BAM92's Avatar
BAM92
What about this one?http://forums.corvetteforum.com/show...ortech+bracketThe Blowerworks one I have would fit the blower you are describing. I am guessing this is for a forward rotation one also.
To vortech v1 supercharger
