Fuel Rail Leak
Old Oct 8, 2008 | 11:52 PM
Corvette Chris's Avatar
Corvette Chris
Default Fuel Rail Leak
Pulled the car into the garage yesterday and smelled gas. Not good.
Pulled apart the intake, and my leak. I believe its the fuel rail return line, on the back side of the fuel rail (left rail). Is there supposed to be an o-ring or something there? I've had this thing apart so many times, I should know by now.
On a semi-related note, I'm having problems with my fuel gauge sender too. Is this just a bad string of luck, or is this ethanol related?
Old Oct 9, 2008 | 12:45 AM
mash557's Avatar
mash557
The back side of left fuel rail on 86 should go to cold start injector. I would think there would be oring as they are everywhere else. Ethanol is causing a lot of problems with small motors and wouldn't be surprised if that wasn't part of your fuel level problem. Sorry but no idea how to fix that one.
Old Oct 9, 2008 | 09:53 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
There is definitely a small o-ring on the fitting at the back of the fuel rail.
Old Oct 9, 2008 | 01:45 PM
Corvette Chris
Thanks guys. I've gotta believe the ethanol has something to do with it.
Just got home from work. Headed out to the garage now.
Old Oct 22, 2012 | 08:02 PM
Mike Wellman's Avatar
Mike Wellman
2nd Gear
I have a 1985 c4 .I have a fuel leak right where the fuel line connects on the pasenger side up front. Is there an O-ring at the conection or do I need to replace the unit.
Old Oct 22, 2012 | 08:03 PM
TA's Avatar
TA
There's quite a few o-rings around the fuel rails. I'd replace them all while your at it. I did all mine last time I had the fuel rails off.
Old Oct 22, 2012 | 08:38 PM
vetteoz's Avatar
vetteoz
http://webpages.charter.net/khasting...uelsystem.html
Old Oct 23, 2012 | 12:05 AM
leesvet's Avatar
leesvet
if one leaks they will ALL leak soon as you reassemble and run.
Get the vitron o-ring kit and be done with it. It takes a fetter ring, barrel type ring in the CS valve. Set o-rings in vasoline, once :set: do not twist,,that tears them.
Old Oct 23, 2012 | 12:34 AM
Mike Wellman
2nd Gear
thanks for info
To Fuel Rail Leak
