Timing question
Old Oct 10, 2008 | 08:47 AM
lrb452's Avatar
lrb452
Default Timing question
I recently installed a new distributor after my 85 jumped time. I have the car running but barely. It has a large cap HEI distributor and I can only turn it clockwise about a 1/2 inch. I was going to lift it and turn the shaft one tooth but then the slot in the bottom won't line up with the oil pump gear. I need to know if I can turn that oil pump gear without moving the position of the crank or cam. Thanks for any help.
Old Oct 10, 2008 | 08:55 AM
Churchkey's Avatar
Churchkey
Not saying its the correct method but I move the distributor a tooth then use a remote starter button to bump the engine over until the distributor drops into the oil pump drive shaft.
Old Oct 10, 2008 | 09:06 AM
Iroc57's Avatar
Iroc57
Flat blade screwdriver, turn clockwise
To Timing question
