Replacing front main seal ...any others?
Old Oct 10, 2008 | 11:08 AM
Trebor's Avatar
Trebor
Default Replacing front main seal ...any others?
Hi Folks:
I am having a leaky front main seal aka crankshaft seal replaced at the chevy dealership on Monday for my '96 LT4. While they are in there are there any other seals that I should ask them to replace as preventative maintenance even if they are not leaking right now?
thanks,
trebor
Old Oct 10, 2008 | 11:44 AM
jrp's Avatar
jrp
Opti & water pump drive seals are also on the timing cover. Also make sure the hub doesn't have wear grooves.
What was their quote, BTW? I plan on doing this myself, but may decide to suck it up if I can't find the time. The REAL holdup, though is the hotcam decision. "While I'm in there", and all...
Old Oct 10, 2008 | 12:48 PM
Trebor's Avatar
Trebor
Thanks jrp:
I asked them to give me an estimate and he said the estimated labor hours is between 3-4 at $90/hour. So figuring in $20 for the seal, $20 ish for anti freeze so a bit south of $500.
trebor
QUOTE=jrp;1567415335]Opti & water pump drive seals are also on the timing cover. Also make sure the hub doesn't have wear grooves.
What was their quote, BTW? I plan on doing this myself, but may decide to suck it up if I can't find the time. The REAL holdup, though is the hotcam decision. "While I'm in there", and all...[/QUOTE]
Old Oct 10, 2008 | 03:47 PM
jrp's Avatar
jrp
I was looking forward to doing the fix myself, but paying a mechanic $450-ish might be worth it.
To Replacing front main seal ...any others?
