Ground strap not grounding?
Old Oct 10, 2008 | 08:37 PM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
Default Ground strap not grounding?
I am having problems getting a good ground on the Delco power antenna motor I just replaced. I get very poor reception and today the fuse blew. There is a ground strap that goes from the antenna motor assembly to the frame just as the original had. For some strange reason it does not get a good ground with this strap setup. Anyone have any ideas what I can do to fix this problem?
Old Oct 11, 2008 | 04:28 AM
toptechx6's Avatar
toptechx6
If you blew a fuse it is not a bad ground, that will cause an open circuit, it takes a short to blow the fuse. You need to check the power wire for cut insulation, pinched under a bolt or something similar unless your new part is a bad one, good luck.
