Stripped spark plug hole
Old Oct 12, 2008 | 08:22 PM
vortex's Avatar
vortex
2nd Gear
Default Stripped spark plug hole
Have a stripped spark plug hole in 96 alm head. Anyone ever use the KD back side thread chaser? (Collapsed rod with tap is inserted into head, rod is expanded and engaged with bottom threads and backed out cutting/clearing threads)
Old Oct 12, 2008 | 08:32 PM
RiktorD's Avatar
RiktorD
I haven't used that one in particular. Chasing the threads from the front or back is simple as ling as there is a bit of thread left. The tap will engage and re-cut. But from my experience, if the threads ar too far destroyed you might have to helicoil it.
Old Oct 12, 2008 | 08:43 PM
ROB502's Avatar
ROB502
find it at NAPA
Old Oct 15, 2008 | 09:18 PM
vortex's Avatar
vortex
2nd Gear
It worked
Old Oct 15, 2008 | 11:31 PM
Ed Ramberger's Avatar
Ed Ramberger
Originally Posted by vortex
It worked
Then the threads weren't really stripped - just lightly damaged...
I have been working on aluminum heads for years. I recommend Time Serts.
http://www.timesert.com/
Old Oct 16, 2008 | 12:53 AM
reoch999's Avatar
reoch999
It worked
There's a God in heaven! (and He loves you)
Old Oct 16, 2008 | 11:46 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Thanks for a great tip! I will have to remember this, they beat the dickens out of a helicoil.
Old Oct 16, 2008 | 11:38 PM
96GS#007's Avatar
96GS#007
Timeserts are expensive, but worth every penny
To Stripped spark plug hole
