lights 91
Old Oct 15, 2008 | 12:57 PM
19774x4's Avatar
19774x4
Default lights 91
with light switch off both rotors motor run. with light switch on both lights rotate to the on pos. and motors keep running.then turn off lights, rotors will not retract lights , but motors still run. should the motors run all the time or shut off when in the off or on pos,
Old Oct 16, 2008 | 11:33 AM
josephf31's Avatar
josephf31
Default The motors
should only run while turning the lights on/off, then shut off...sounds like you have some worn out gears/bushings...
Old Oct 16, 2008 | 12:14 PM
janarvae's Avatar
janarvae
Check out the sticky at the top of the C4 tech section.
To lights 91
