D44 oil
Old Oct 16, 2008 | 04:32 PM
GS023's Avatar
GS023
Default D44 oil
Any recommendations on what oil to use in my Dana 44?
Old Oct 16, 2008 | 05:20 PM
jrp's Avatar
jrp
I used the GM oil & additive. Other than using 2 bottles of additive rather than one, I didn't see much point in trying to outsmart GM on this one.
Old Oct 16, 2008 | 05:26 PM
GGTOOLS's Avatar
GGTOOLS
I used Royal Purpel w/ GM additive. no troubles
Old Oct 16, 2008 | 05:28 PM
Monks's Avatar
Monks
Why would you use 2 bottles rather than what GM recommends?
Don't you want you limited slip to work ?
Old Oct 16, 2008 | 05:31 PM
Monks's Avatar
Monks
Does Royal Purple have friction modifier it in allready?
Redline gear oil has 2% from the factory, it works great in my D44
with no additional additive.
Old Oct 16, 2008 | 05:32 PM
Aardwolf's Avatar
Aardwolf
I'm using the Redline as well, it has additive and I don't add more.
Old Oct 16, 2008 | 06:05 PM
mako41's Avatar
mako41
What Redline diff oil did you use for your D44A diff? Did you suck the old fluid out of the fill hole? I don't see a drain plug.
What does GM spec? 75w/90??
For those that used the GM friction modifier ~ how much?? Thanks.
Old Oct 16, 2008 | 08:45 PM
Monks's Avatar
Monks
I used the factory weight in the Redline. I had a drain plug
that I drilled and tapped.
Redline also makes friction modifier, but I never needed it.
Suck the old fluid out and fill with oil, Drive the car in a parking
lot in tight circles and see if you get "chatter" from the rearend.
If you get chatter, add 1/4 bottle of modifier. repeat until you get no noise.
I never needed to add modifier with Redline. Keep in mind that
I autocross my car and need the LS to work. If you car is a DD,
just dump in a bottle of Friction Modifier.
Old Oct 16, 2008 | 10:39 PM
jrp's Avatar
jrp
It's not just me. Using two bottles is practiced by many people here, as demonstrated in at least half of the threads I clicked on in my search just now. Maybe it's overkill, but I've never seen anyone else even hint that it hurts anything.
It apparently originated as a Gordon Killebrew recommendation, and based on the posters who stated so, I have no reason to doubt it.
Old Oct 16, 2008 | 11:36 PM
96GS#007's Avatar
96GS#007
I use Red Line 75W90, no extra additive added since it has it already mixed in. Make sure the car is level and fill until it dribbles out the fill plug. Takes about a quart and a half.
Old Oct 17, 2008 | 01:26 AM
Monks's Avatar
Monks
Using 2 bottles won't hurt anything, it will make you Limited slip
not work well (Slip too much). One bottle of GM is 4% friction modifier, (GM spec.)
Redline has 2%, and I have never added more than that.
Since I autocross, I want my LS to work. I can't imagine why
Gordon K. would recommend using more. Do you know why?
Old Oct 17, 2008 | 08:33 AM
milsurpman's Avatar
milsurpman
iagree:
I use one bottle of gm ls additive with mobil 1 75-90 in my dana 44 and its nice and quiet in turns. No reason to add anymore then you need.
Old Oct 17, 2008 | 09:00 AM
PDQUIK95's Avatar
PDQUIK95
From: Portsmouth Virginia 396LT4 435RWHP/400RWTQ Best so far 11.26 @ 123mph
Joe,
I use Amsoil synthetic 75-90 with one bottle of limited slip additive following intial break-in of new gears,clutches, and bearings with conventional GM gear oil after a couple hundred miles.
Rick
Old Oct 17, 2008 | 09:16 AM
Aurora40's Avatar
Aurora40
I thought GM no longer sold the oil they originall spec'd for our diffs? Or am I just confused with all the other stuff GM has dropped for our cars?
I use Mobil 1 75w-90 and put in one bottle of the GM additive.
Old Oct 17, 2008 | 11:26 AM
jrp's Avatar
jrp
What you're saying makes sense. I don't remember if I ever saw the reasoning. Maybe to quiet things down or slow down wear?
I have had no indication of too much slip, but it certainly doesn't get as much of a workout as autocross.
The oil I got was the original part number, at least, but it was a couple of summers ago. I wouldn't be surprised.
Old Oct 20, 2008 | 11:43 AM
GS023's Avatar
GS023
There is a new part number for the GM oil. 89021669
None of the local dealers have it in stock.
Old Oct 21, 2008 | 01:54 AM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
I use the AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 in my 02 Z06 dedicated track car and 06 CTS-V daily driver. This fluid does have the additive in it and neither of my cars requires extra additive to prevent diff chatter.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
To D44 oil
