QUICK!! WIRING HARNESS QUESTION!!
Old Jan 10, 2002 | 12:06 PM
dtorc4's Avatar
dtorc4
Default QUICK!! WIRING HARNESS QUESTION!!
When switching to the 165 computer for the '85 style, do you need the 165 plug to the ecm or do you use the stock plug from the '85. Might have found a deal if I don't need the 165 plug. Thanks!!!
[Modified by dtorc4, 4:13 PM 1/10/2002]
Old Jan 10, 2002 | 01:03 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: QUICK!! WIRING HARNESS QUESTION!! (dtorc4)
I think if you use the 85 plugs.. you need to re pin them and and the MAF relays
Old Jan 10, 2002 | 02:46 PM
drive it's Avatar
drive it
Check out http://www.eecis.udel.edu/~davis/z28/ He's done the swap to 165 and then to a 730 and done a great job of documenting everything.
Old Jan 10, 2002 | 03:57 PM
dtorc4's Avatar
dtorc4
Default Re: QUICK!! WIRING HARNESS QUESTION!! (drive it)
Thank you guys!!! :cheers:
Old Jan 10, 2002 | 04:02 PM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
Default Re: QUICK!! WIRING HARNESS QUESTION!! (-=Jeff=-)
:yesnod:
when I was going to do this (when I had my '85) I remember hearing that the '85 plug ends work fine, but just be sure to re-pin the wires that are different.
To QUICK!! WIRING HARNESS QUESTION!!
