Non Corvette related question
Old Oct 17, 2008 | 01:58 PM
shamdave's Avatar
shamdave
Default Non Corvette related question
OK i know this is not a vett, but i need some help with something that should be easy. I need to know how to replace a belt tensioner on a 1995 buick park ave. I can not seem tofigure this one out. any help is appreciated.
Old Oct 17, 2008 | 03:15 PM
Red Dwarf's Avatar
Red Dwarf
This forum (Buick) gave me some help a while back relative to my sister's Buick. Give em a try.
http://www.automotiveforums.com/vbulletin/index.php
Old Oct 18, 2008 | 05:23 PM
redrose's Avatar
redrose
just did one on neighbors 96 ick, 3.1 cent not 3.8 like your park ave...tensioner was frozen, wouldn't move to get belt slack...just removed the center bolt from the tensioner arm and prayed that the bolt would not mess up/crack the threads of the supporting housing as the end came out...it didn't, probly cause there was almost zero tension being applied, idler pulley could be turned inside the serp belt by hand...but if the serp belt was in high tension, would have cut the belt rather than risk the housing
Old Oct 18, 2008 | 09:39 PM
cbryant's Avatar
cbryant
some of those tensioners were part of a huge bracket that had two coolant elbows attached. look closely and see if this is the case, if it is the whole bracket assembly must be replaced
Old Oct 18, 2008 | 11:57 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
It's a GM, can't be that difficult. Normally a 14mm or 5/8
To Non Corvette related question
