Windshield washer pump?
Old Jan 10, 2002 | 11:04 PM
MDC9966's Avatar
MDC9966
Default Windshield washer pump?
I noticed mine doesn't work, where is the pump and how do you get to it? Do you take off the side panel or is it someplace else?
Old Jan 11, 2002 | 01:23 AM
LWesthaver's Avatar
LWesthaver
Default Re: Windshield washer pump? (Curtis629)
The pump is mounted to the bottom of the washer bottle. You will need to remove the side panel, remove the bottle and replace the pump.
More info on replacing the pump can be found in this thread:
http://corvette.westhaver.com/1988/W...WasherPump.htm
Old Jan 11, 2002 | 08:58 PM
mash557's Avatar
mash557
Mine works, but not enough pressure. I checked the pump out and to me it looks like a gold plated pain to replace. That nut inside, not directly below the opening has me concerned. Maybe I can find one with pump and reservoir so I won't have to. I know it possible, just not sure. I'll check the URL for tips.
To Windshield washer pump?
