TPI Batch Fire Question
Old Oct 23, 2008 | 12:19 PM
Yguy's Avatar
Yguy
Default TPI Batch Fire Question
As most of us know, our beloved TPI systems are a "batch fire" system,
meaning that when the injectors are triggered, they do so in groups of
2-4-6-8 and 1-3-5-7. We also know that since the introduction of the LTx engines, FI systems have been using a sequential fire system. This fires off the injector in sync with the opening of the corresponding valve
and as such reduces fuel drop.
While I don't know of any way to convert our L98's to sequential, how about re-arranging things to work more closely with the mechanical timings of the engine components? IF I understand things, our injectors fire as I stated above, 1-3-5-7 and 2-4-6-8 while our firing order is
18436572. Ok, so would it work if the injectors were wired to fire 1-8-4-3 and 6-5-7-2?
I certainly recognise the fact that even at moderate engine speeds, things occur VERY quickly inside. But if it were of no value, why is the general still using sequential systems when they have the habit of using
last years idea whenever possible?
Constructive comments are very welcome...........
Old Oct 23, 2008 | 12:27 PM
Firevette's Avatar
Firevette
Cruise-In X Veteran
Intresting. I never really thought of it that way.
Old Oct 23, 2008 | 12:31 PM
cmcbunch's Avatar
cmcbunch
You would have to find someone with a lot of custom efi experience to answer this one. I dont know THAT much about engine timing.
Old Oct 23, 2008 | 12:40 PM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
interesting however, tpi's from gm fire all 8 at once contrary to popular belief. The 2 fuses are for the load but the grounds for all 8 are common. Here's an excerpt from gm performance. I was always under the same impression untill I put on two noid lights on the oppisite banks.
"Most early EFI systems were batch-fire systems where the ECM fired all eight injectors simultaneously. Usually batch-fire systems fire the injectors once per engine revolution. This way, the injectors could be sized small enough to be more easily controlled at idle. Later, sequential EFI systems were refined to fire an injector a few degrees before the intake valve opened. Generally, sequential injection offers more precise fuel control at the price of increased complexity. But on production engines, the benefits are more in the area of emissions and driveability than in performance".
Old Oct 23, 2008 | 12:51 PM
Firevette's Avatar
Firevette
Cruise-In X Veteran
I didnt know that. You learn something new every day.
So much for re-inventing the wheel.
Old Oct 23, 2008 | 12:58 PM
Calderone's Avatar
Calderone
It was interesting !
but i guess 8 firing at once its better ?
cool to know !
Thanks !
Old Oct 23, 2008 | 01:06 PM
SCCA VETTE's Avatar
SCCA VETTE
What is really amazing is that the L98 gets the mileage that it does firing all 8 at once. I always wonder what % better it would get if it were sequential when I thought it was batch (bank) fire also, that % just went way up.
Thanks to FIC for not only good products but good information.
Old Oct 23, 2008 | 05:23 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Consider that even at 600rpm, assuming fireing once per rev, the injectors fire every .1sec; I don't think there will be much fuel loss up the intake runner in that time period, which is the only "escape path" for the fuel assuming the intake valve is closed.
The only way "improvement" could come is if an intake valve were partially open when fuel is injected; then sequential injection just before valve opening would benefit in power/economy.
Old Oct 23, 2008 | 05:30 PM
ultraviolet70's Avatar
ultraviolet70
No point to converting it.
Even the early LT1s (92-93) were batch fire.
Now knowing that what performance, emission, milage or even idle characteristic differences are there between a 93 batch fire LT1 and a 94 sequentally pulsed LT1 the answer is none. The main reason for going to sequential fire was for the future implementation of OBD2 diagnositics with missfire diagnostics, not for performance.
Old Oct 23, 2008 | 11:06 PM
larryfs's Avatar
larryfs
that;s interesting, even with noid lights, could the human eye detect even if the firing was a milli second off?
you would need an oscilloscope to see it I would think.
Old Oct 24, 2008 | 01:10 AM
Yguy's Avatar
Yguy
It looks as if I've once again learned something here on the forum.
As I said, the events that occur inside an engine happen at a high rate of speed, so it's no wonder that there's little to be gained by going sequential. Thanks for the help on this. This and ?'s like it are some of those things I end up wasting my daydreams on, when I could put them to use trying to increase performance on ..... something...
Thanks guys, I do appreciate the responses. Bob
Old Oct 24, 2008 | 10:16 AM
redrose's Avatar
redrose
"all-out" small and big-block racing engines have used "constant flow" injections from hilborn/kinsler/etc for decades, strictly "mechanical" with ZERO electronics..."idle" below 1k rpm is "iffy" due to radical cams + difficult triming of fuel flow, but top end power is very "satisfactory"
Old Oct 24, 2008 | 01:05 PM
EastCoastHD's Avatar
EastCoastHD
Great thread!
Old Oct 25, 2008 | 07:48 PM
jnaugle775's Avatar
jnaugle775
Good Questions and thoughts. I have often wondered these same things
Old Oct 25, 2008 | 11:25 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Great piece of info! As with Bob, this was something I wondered about as well. Though UV70 is the first person to say this (that I've seen), I believe it. I received info on my ODB2 family car pin-pointing a misfire once. That was helpful to determine the location of a miss. And, as 65Z01 points out, injectors are "firing" faster than every 1/10th of a second. There isn't much time for the gas to "settle". Finally, the air pulses in the intake are so powerful, they really help with atomization.
The later was explained to me a couple of years ago, but I had a hard time with it. And, I think there's still room for improvement, Bob. I think injectors that atomize the fuel best will provide much of the improvement you might have hoped to get thru a conversion to sequential firing.
Reports from owners who've converted to the BoschIII type injector (as documented by FIC) have shown that atomization is an issue where you might want to focus your attention. At least that seems more promising.
To TPI Batch Fire Question
