Headlight
Old Jan 11, 2002 | 09:50 AM
mike72's Avatar
mike72
Default Headlight
The passenger side headlight opens fine, but it is hanging up on something when I turn it off. I can open the hood and it will close. I have tried to find what it might be catching on with no luck. Anyone else have this problem?
Old Jan 11, 2002 | 11:17 AM
Muffin's Avatar
Muffin
Default Re: Headlight (mike72)
Been there. Check the routing of both the wire bundles and the vacuum hoses. If that does not fik it check the rubber seal . I have had both to bind the left headlight and keep it from closing.
Old Jan 11, 2002 | 11:32 AM
mike72's Avatar
mike72
Default Re: Headlight (Muffin)
Old Jan 11, 2002 | 01:43 PM
mike72's Avatar
mike72
I found it! the overflow pipe going into the coolant recovery tank had shifted out of place by a fraction of an inch and was binding against the headlight housing. :D
To Headlight
