Code H-32 EGR valve
Old Oct 24, 2008 | 04:45 PM
78pacer's Avatar
78pacer
Default Code H-32 EGR valve
I got that code last night after my SES light went on, then off after 5 mins. How difficult was replacing the EGR on the LT1? Factory shop time says .3 hrs. What should I beware of? Any tips or tricks?
Mike
Old Oct 24, 2008 | 04:54 PM
JAKE's Avatar
JAKE
Changing the EGR valve is really easy to do. I changed the one on my previous 96 in no time. There are only a couple of bolts to be removed.
If I remember correctly there was only one obstruction to getting to the EGR bolts but it was easily moved out of the way. I changed mine from standing on the driver's side.
Sometimes a good spraying with carb cleaner can remove the build-up of carbon that can cause the EGR valve to stick..
Jake
Old Oct 24, 2008 | 07:01 PM
78pacer's Avatar
78pacer
Thanks Jake,
I put a hand vacuum pump on it tonight and it moves freely, but will not hold vacuum. The FSM says it should hold for at least 20 secs. This drops right down. I would suspect the bladder is bad. Where did you get your replacement, and what was the approx cost?
Mike
Old Oct 24, 2008 | 07:07 PM
cbryant's Avatar
cbryant
get an ACDelco part. I have had bad luck with aftermarket.
Old Oct 27, 2008 | 09:06 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Be sure and inspect your EGR diaphragm, too. Mine was visibly cracked and dry-rotted, leaving it unable to hold vacuum when commanded by the ECM and EGR solenoid.
I replaced it with a new one and voila! No more code 32.
Old Oct 27, 2008 | 06:50 PM
78pacer's Avatar
78pacer
Thanks for all the replys! I ordered both the EGR and the vacuum solenoid. Might as well be done with it.
Mike
To Code H-32 EGR valve
