what o2's???
Old Jan 11, 2002 | 02:15 PM
Blues77's Avatar
Blues77
Default what o2's???
Doing the full tune up today, opti, waterpump, msd wires, and NGKs. (thanks for all the tips). I thought I read the bosche (sp?) 02's werent good for our LT1's is this true? Should I just get the cheapos?
Old Jan 12, 2002 | 12:16 AM
YLO Z06's Avatar
YLO Z06
2023 C5 of the Year Finalist - Modified
Default Re: what o2's??? (Blues77)
Right, dont get the Bosch O2 sensors. Get the GM sensors. They are the correct ones for the car and already have sealant on the threads. Your 1994 needs 3 sensors. They run around $43 a piece and are available from Ecklers, The Last Detail, etc.
Old Jan 12, 2002 | 04:41 AM
merrick's Avatar
merrick
Default Re: what o2's??? (94vette)
I thought Bosche makes good products. What's wrong with the O2.
Old Jan 12, 2002 | 08:20 PM
Guest
Guest
Posts: n/a
Hmmm.....thats strange...I replaced my bad O2 with the Bosch and haven't had any problems. Actually, increased my gas mileage. (of course, I realize this is b/c I had a bad O2) What is the bad thing about the Bosch O2's?? :confused:
Old Jan 12, 2002 | 11:10 PM
YLO Z06's Avatar
YLO Z06
Default Re: what o2's??? (NONO5.0)
People have reported problems with the Bosch O2 sensors -- the connectors were bad and some sensors were faulty. No problems with OEM sensors :chevy .
Old Jan 13, 2002 | 11:12 AM
Nathan Plemons's Avatar
Nathan Plemons
I've always hated Bosch, but that's about the only brand O2 sensor you can buy around here without going to the dealership. Anyway, as far as O2 sensors go I've never known anybody to have a problem with them. But then again yesterday I used a pair which led to this post
http://forums.corvetteforum.com/zerothread?id=217443
I'll drive the car again today and see if it did take care of the problem.
Old Jan 13, 2002 | 11:14 AM
Nathan Plemons
BTW, what's up with the 3 O2 sensors? I thought only the OBDII cars were annoying enough to have that sort of thing, and then I thought it was 4. Two in front of the cats, two behind. Where's the 3rd on on the 94's?
Don't get me wrong, I don't doubt you, you have a 94 and I don't. I'm just wondering.
Old Jan 14, 2002 | 02:51 PM
YLO Z06's Avatar
YLO Z06
Default Re: what o2's??? (Nathan Plemons)
Nathan,
Why 3 O2 sensors? I have no clue... Probably has to do with the varying stages of the OBDI to II upgrade. 94s and 95s have varying degrees of OBDII stuff, leading up to the 96 full-blown OBDII system. Anyway, one sensor in front of the each cat and one sensor behind the passenger cat.
Old Jan 14, 2002 | 04:14 PM
BAdAzZV8's Avatar
BAdAzZV8
The '94s were the test mule for the OBDII system. They put an extra O2 sensor behind the cat, but the one behind the cat doesn't even send info to the computer.
To what o2's???
