threaded ait sensor
Old Oct 26, 2008 | 09:11 PM
Guitarguy's Avatar
Guitarguy
Default threaded ait sensor
hey everyone i,m putting in a vortech supercharger kit and i messed up my ait sensor trying to thread it myself. does anyone know of a theaded ait that i can get in a parts store?
Old Oct 27, 2008 | 08:36 PM
arlockstedt's Avatar
arlockstedt
would also like to know of one.....the boost seems to have almost stripped mine
Old Oct 28, 2008 | 01:56 AM
Mo_Bandy's Avatar
Mo_Bandy
Guys,
Check with GReg at blowerworks.net
He may have them in stock.
MO
Old Oct 28, 2008 | 08:51 AM
mn_vette's Avatar
mn_vette
Guys,
I run a threaded IAT on my turbo setup. It is a basic GM part. I went into NAPA and asked them to look at their book on GM sensors and they have pictures of what things are. I found one with the same plug end, but with a threaded end. I think they had one in stock and it wasn't very expensive at all.
Sorry I don't have a part number, but it shouldn't be too hard to track down. Good luck.
Old Oct 28, 2008 | 10:51 AM
lcvette's Avatar
lcvette
the buick grand national sensor is a caged threaded IAT sensor and should be something you can grab at any local autoparts store.. hope this helps!
Chris
Old Oct 29, 2008 | 03:24 AM
BAM92's Avatar
BAM92
Where are you guys locating your sensor on the car? Air filter, discharge tubes, or dog house?
Old Oct 29, 2008 | 08:42 AM
mn_vette's Avatar
mn_vette
I have my sensor right before the throttle body. This tells you what your post compressor/IC temperature is, and that is what your computer should be setting the timing for, the air entering the engine.
Old Oct 29, 2008 | 09:14 AM
lcvette's Avatar
lcvette
as close to the throttle body as you can put it is the best so it has a chance to get closer to accurate.
Chris
Old Oct 29, 2008 | 11:25 AM
AKS Racing's Avatar
AKS Racing
On the old MRII set-up I had it mounted on the elbow feeding the TB ~2" in front of the TB.
Currently, mine is mounted on the bottom side of the intake elbow right at the 4BBl flange as it enters the intake manifold. On this set-up, I mounted it further down the intake tract so that I could monitor the cooling effect of the MeOH.
Aaron
Old Oct 31, 2008 | 07:39 AM
BlowerWorks's Avatar
BlowerWorks
Supporting Vendor
Hey Guys, On a supercharged LT1/LT4 you should NOT put the IAT sensor in the blower air discharge stream if using the GM PCM. Doing so causes the PCM to pull a lot of fuel! Remember the IAT sensor cannot see mass air flow only temperature. On a blown set-up the warm air from the blower is indicative of higher mass air flow that the GM PCM does not recognize. I always locate the sensor where it will see ambient temps. I then plug the hole for the IAT with a 1/2-20 hex plug and some silicone sealant.
Best regards, Greg
Old Nov 7, 2008 | 09:43 PM
Wrenchp's Avatar
Wrenchp
6th Gear
DIYAUTOTUNE.COM. They are a Megasquirt dealer and have the threaded sensor that you need.
To threaded ait sensor
