Emissions Problem
It is a LT based motor - 383 stroker, Lt4 AFR heads, Lt4 stock camshaft, Lt4 intake. It has about 15k on the rebuilt motor. It just barely passed smog a year and a half ago. I have 2 different PCMs the
1st was programmed by PCM for Less, the 2nd by Fastchip.
Using the 1st PCM the car failed with the NO number being too high, the CO & HC numbers were good.
Using the 2nd PCM the car failed with the CO number being way too high - actually a "gross polluter". The car was spewing black smoke out of the right side exhaust. The car started running poorly, so I pulled & replaced the right side spark plugs which 3 of 4 were full of carbon & smelled of gas. I also replaced the forward right side Oxygen sensor.
I would hope to not have to start replacing parts one at a time until I happen upon the problem.
Any help would be greatly appreciated.
What year is your car? If its OBDII, you can get software to tune it yourself.
