i took all the screws off and it lifts up, but the roof spring catch prevents it from coming out, i searched and found no results please assist, thanks.
First, you have to get a good grip on the catch ****, and pull straight up. The black plastic catch **** is press fit onto a stub that is forced into it.
Pull that off, and your trim comes off nicely.
Tip:
pack this area with foam to keep from hearing the antenna relay when the antenna goes up and down.
also, you might get a little dynamat, or foil lined jute and line this area to help keep the exhaust noise from echoing off the hatch glass.
