T.B. Coolant By-Pass
Old Oct 31, 2008 | 03:37 PM
CAJUN C4's Avatar
CAJUN C4
Default T.B. Coolant By-Pass
Anyone do the T.B. Coolant by-pass?
Is it worth it?
Gets Pretty Hot Down here in South Louisiana.
Old Oct 31, 2008 | 04:20 PM
MTVette's Avatar
MTVette
Yes.
No.
Old Oct 31, 2008 | 04:31 PM
Yorcci's Avatar
Yorcci
Is it worth it?
Yes, I have done it. Worth it? Worth what?
It helps, for example in (my) case if you should encounter problems when updating original runners with large tube runners and then had to put the orig. runners back and try to swap them after a day or two and again and again... In this particular case, you wouldn't have to drain and fill your coolant every time you take the plenum off.
Also you can touch plenum after driving without burning your fingers. It still will be hot to touch, but noticeably cooler when bypassed.
You might also gain a horsepower or even two.
And I did NOT have ANY problems during last winter, even though some people suggested, that I would. Meaning that TB should freeze. I didn't. Even though I tried to drive in many different weather conditions. Freezing cold, near freezing point (above and under), in clear weather, while snowing, you name it.
Old Oct 31, 2008 | 04:38 PM
warren s's Avatar
warren s
Its free -[IMG][/IMG]
Old Oct 31, 2008 | 10:46 PM
aminnich's Avatar
aminnich
Works for the 95-96 LT1/4s, and you will actually eliminate a short 90* molded hose and two clamps==less places to leak. For all other years there is some plumbing required.
Old Nov 1, 2008 | 08:47 AM
WW7's Avatar
WW7
Anytime you can get cooler air into your motor its a good thing. By doing a bypass you are cooling the plenum down causing the air entering to be cooled down also. So yes its a good thing,and its worth it....WW
Old Nov 1, 2008 | 10:13 AM
MK 82's Avatar
MK 82
As mentioned, the 96 is super easy to do and cleans up the plumbing and eliminates a possible leak. Makes removing TB a piece of cake.
Worthwhile.
Old Nov 1, 2008 | 11:56 AM
Rob10R's Avatar
Rob10R
Cheap and Easy Mod!!
Old Nov 1, 2008 | 01:37 PM
Aardwolf's Avatar
Aardwolf
Much easier to work on with those hoses removed. One thing I have always found funny is I can pretty quickly grab the headers but trying the same thing on an intake tube would burn me. The intake really heat soaks.
Old Nov 1, 2008 | 10:22 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
Old Nov 4, 2008 | 11:20 AM
CAJUN C4's Avatar
CAJUN C4
Great Info.
I'm Sold..I'm gonna due the 95' & 96'
Thanx Guys
And speaking of Cold Air....
Now..How about a K & N or Green Air Filter ? and / or a cut Lid?
Old Nov 4, 2008 | 12:07 PM
cmcbunch's Avatar
cmcbunch
Sometimes I wonder what the hell the engineers handling engine configuration are thinking. They already have an exhaust crossover that routes hot exhaust into the intake to heat up the manifold. I doubt that the throttlebodies on these cars froze enough to warrant this. Go ahead and remove it. It shouldnt be on a car that isnt in alaska.
Old Nov 4, 2008 | 03:07 PM
CAJUN C4's Avatar
CAJUN C4
I hear Ya
Thanx
Old Nov 4, 2008 | 05:12 PM
85vette-84vette's Avatar
85vette-84vette
I did that mod on my 85 vette, it is easy and "they" say its worth 6 hp
Old Nov 5, 2008 | 01:04 PM
jimyz's Avatar
jimyz
I have an 86, can you tell me how to do this mod?
Old Jul 7, 2012 | 08:52 PM
BucfanTitan's Avatar
BucfanTitan
I know this is an older thread. The picture is awsome. Do I remove the hose on the bottom or the middle hose on the passanger side of the TB.
Thanks for the help and the great picture.
Old Jul 8, 2012 | 12:08 PM
LT4 F45's Avatar
LT4 F45
Just done it on the LT4 and cleaned the T.B intake at the same time...
Very easy sunday morning DIY job
Thanks guys!
Old Jul 9, 2012 | 12:36 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Originally Posted by MTVette
Yes.
No.
Hang some NOS stickers on her.
Same effect.
To T.B. Coolant By-Pass
